What do i need to know to install a winch?
TNDRIVER
448
Cleveland,TN
I've got a garden variety 2dr soft top M998.
I've also got the pictured mile marker hydraulic winch and mounting plate.
Presumably I need a couple of hydraulic hoses. What else?
Are there instructions somewhere in the TM for how to install?
Is that all you have??? I have the "near" complete kit and although I have not looked at the thing in a while I'm pretty sure there are a couple of brackets, a hand full of grade 8 bolts, the plug that is mounted in the dash with the wiring to the solenoid valves on the winch and a controler that are needed for sure along with the two hoses. The dash plug shows up occasionally with the regular suppliers but expect a hit in the pocket book. The pieces are in the TM's.
  • Like
Reactions: 98G
juanprado
2,812
Metairie/La (N'awlins)
All the mentioned parts plus yellow controller (usually on ebay) or black ( warn for electric) if you reverse the wiring, 2 longer lower control arm bolts, wiring harness.
Mile marker did sell me the parts I was missing directly.
I can't recall size off hand but look on my thread for a suggestion on a mm crowfoot and short stubby wrench for the nut on one of the hoses is real tight fit.
TNDRIVER
448
Cleveland,TN
I can't tell you how much I appreciate this!!!
This is exactly what I was looking for.
FYI... don't know about the situation presently but Mile Marker used to be pretty uppity about any part with a government part number . Some have had good luck others not so much. My 2 cents.
