Somemedic
- 0
- 16
- Hobart, IN
DSKchehy: you are going to be replacing your IP soon. Sell it or make the preperations.
Fuel on the rear tailgate sounds like the fuel that collects in the motor valley cause the IP is leaking and needs rebuilt. Get a bright flashlight and look on top of the motor. Suspect the injectors if the top of the motor is dry but I have a feeling it wont be.
Ive never had the injectors rebuilt but the fuel on the tailgate went away after the IP was rebuilt and the top of the motor is dry. You will also sometimes see fuel leaking out of the flex plate inspection cover weep hole.
Buy a good quality head gasket kit and start shopping for an injector pump rebuild shop. Might also get some rebuilt injectors at the same time. Id bet she'd scream after the rebuild.
Now you know what to do with that tax check. Around $1100 to farm it all out.
