I have been adding a bottle of 2 cycle oil to each tank but it sounds like that may not be enough. Can you explain the suggestion to add 3-4 quarts of motor oil to a tank of fuel a little more? Are we talking cheap 30 weight oil? What should I see when I do and what effect should it have on mpg?
I think you're wasting your time and risking expensive pump damage unless you're very careful (with used motor oil). All the stories you hear about it being historically used for years are pretty much nonsense when put into the context of the 6.2 diesel. That because the 6.2 uses a distributor type injection pump. The big trucks use in-line pumps and an there is a huge difference in reliability, durability, and longevity. A big-rig in-line pump has a separate injection pump for each cylinder. So, if there are 8 cylinders, there are 8 pumps. A "distributor pump" like the 6.2 uses has one tiny pumping section, even though there are 8 cylinders to feed. So, the pump is hooked to a fuel distributor and that is the most expensive part of the pump, and the least tolerant to alternative fuel mixes.
If you carefully use motor oil in your 6.2 fuel tank, you'll burn it off OK, but you're going to gain just about nothing.
In regard to adding lube to the diesel fuel? It's been well tested under controlled conditions. Motor oil gives lousy "added" protection as compared to other things, like two-stroke motor oil. Truck stops, historically did throw waste oil into the big diesel tanks and for that use, it worked fine and got rid of lots of waste oil.
Also, about the myth of the first diesels being run on peanut oil. The first diesels ran on versions of coal and lamp oil. Also, Rudolph Diesel's first successful engine (what we now often call a "diesel)" was the second, not the first. Dugald Clark was first in 1878. Diesel didn't get his going until 1983. And, Clark's first compression-ignition engine later became the platform for the most famous "diesel" in the world - the Detroit supercharged two-stroke.
And, one note about tires. At least in my experience, nothing gives better mileage than small 235/75-15" tires. Bigger tires do drop RPMs, and also give more rolling resistance and more air resistance due to increased vehicle height.
I've had over 20 6.2 powered trucks and never had a single one that did not lose MPGs with bigger tires. If someone's else's experience differs, I have no idea how to account for that since it goes against physics.
Lube additives, In Order Of Performance, best to worst:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
1ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
