53
Rio Vista,Ca
Took my M934 out for a spin. Shift from 2nd to 1st is a lot smoother. I recently changed tranny fluid to ATF and new filter. the blow off valve on my air dryer seems to get stuck partially open sometimes. if I put a ratchet up their it closes. Any ideas on what is causing this?
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Typical sticking or in need of cleaning. You can buy one from guy here that is updated and cheaper than redoing yours. Check the vendors section or parts classifieds
Sent from my SM-G860P using Tapatalk
big block 88
Topeka/Kansas
I have been looking at backup cameras too and my thought was to hook it up to a toggle switch. I know there are ways to hook them up so they come on automatically when you put your vehicle in reverse, but I like the thought of being able to turn it on while driving if needed to have a rear view mirror kind of set up. Just my thoughts on it.
Mine are on a 3way switch. Up is front low light camera and down is rear view. My monitor can handle 4 feeds so I may install another toggle with side rear view cameras for the blind spots.
simp5782
9,509
Mason, TN
Your in Kansas, I don't know why you need a backup camera, not like there are any trees to back into! Everything else is just a misplaced wheel chock!
simp5782
9,509
Mason, TN
Finally got my shifter cable replaced. That was the biggest PITB I have ever done in my life. I could have pulled the engine and transmission out quicker than I messed with that thing for a week! I tried to use a replacement cable I got and it would not hookup at all. It irritated me so much that I just yanked the whole shifter out of another truck and finally got it to line up. It took a lot of adjustment. I couldn't get the replacement cable to line up at all the cover over the ends where the cable comes out of are just too long. So now my shifter has a fire extinguisher holder on it. Going to work on making a toggle switch box for all my other gismos
Also got my spare tire holder installed that I stole off my M934. I will be cutting the spare tire rack from the 931 (on the left) to make room for the winch. I have thought about not using it anymore and just making some type of system for the winch to lift stuff into the back of the truck.
WYomer
Wyoming
Hauled lots of gravel 13,369lbs one load and 13,611 the next. Then loaded up lots of scrap wood and scrap metal is next.
I put my BBW mud flaps on too! Thats Big Beautiful Wyoming for those of you with dirty minds like me not the other acronym!
Another Ahab
4,955
Alexandria, VA
They're just no mudflaps like the classic Wyoming and the classic Montana mudflaps; the best.
I can't recall for sure, but Colorado might have nice flaps, too (just not coming to mind for some reason).
Can you post a pic here, please?
gottaluvit
Don't you just love it when you tell them "5 tons" and they always overload you. I guess they figure they aint paying the fine. It can't be that hard to know the weight of what size aggregate fills the bucket of the front end loader. I was very tempted to drive back to the pile and tip the gate, but didn't want to seem cocky being I knew I would be back.
Spyderman
40
Alexandria KY
You do know it holds 10 tons right?
Sent from my SM-G930F using Tapatalk
gottaluvit
Yes, but my data plate says 5 tons off road and 5 tons on road. My bmv allows me to determine the gvwr and applies the license fees accordingly. Then they give me a sticker to put on the rear plate that has a "34" representing the gvwr. If the portable scales get me with 7% over what number is on that sticker, I get the fine.
big block 88
Topeka/Kansas
not saying you are lieing but your data plate is wrong or you misread it. On road is 10 on every 939 series truck i seen or worked on.
