Csm Davis
- 405
- 83
- Hattiesburg, Mississippi
Actual 939 air ride seats and console
Sent from my SM-G900V using Tapatalk
Source for these??
Source for these??
They are worth it, we bought a lot of 20 I think about 4 years ago. The foam is different says my upholstery guy and my backside, believe that it is some of the newer MRAP type foams to prevent spine injury these are the second type seats in the up armored 939p2 the older seats were mounted on a sliding rail that traveled up and down with what we're basically air shocks. And the console is made of aluminum with mounting for a radio and amplifier in the middle section and air conditioning underneath, the top shelf unbolts for easy access to the radio gear, but yes it is meant for a gunner to stand on and the whole thing is made out of 1/4" aluminum very strong.They pop up on Fleabay every so often. Pretty pricey.They come in the ROPS trucks and i think anything with armoring/ac as far as M939s and M35s. They are no different than a civilian seat really. I got a great aftermarket air ride from a big truck junk yard for about $100. .
The center console is massive and the steel is retarded but its meant for a gunner to stand on. I swear the first time I saw one I figured it weighed as much as the transmission under it.
That one in the ROPS i towbarred must have been the strongest aluminum i have ever felt.They are worth it, we bought a lot of 20 I think about 4 years ago. The foam is different says my upholstery guy and my backside, believe that it is some of the newer MRAP type foams to prevent spine injury these are the second type seats in the up armored 939p2 the older seats were mounted on a sliding rail that traveled up and down with what we're basically air shocks. And the console is made of aluminum with mounting for a radio and amplifier in the middle section and air conditioning underneath, the top shelf unbolts for easy access to the radio gear, but yes it is meant for a gunner to stand on and the whole thing is made out of 1/4" aluminum very strong.
You can feel the difference between 1/4" steel and 1/4" aluminum without picking it up? Only other way would be hammering on it and I hope you didn't beat the paint off somebody's console. Yeah if it was steel I would have to use the wrecker to lift it but I can lift the front of it with one hand and I put mine in by myself in a 931A2 so about a 5-6 foot lift to get it in the cab.That one in the ROPS i towbarred must have been the strongest aluminum i have ever felt.
Sent from my SM-G860P using Tapatalk
What term(s) should one search for on eBay for the basic version of this box (that I assume you modified some)?Here is the console I made for my 817 from a basic box that is offered on fleebay. I'm putting in the same (as the passenger seat) into my deuce now...and another console/storage box like it.
Well yes, highly modified but a great start. TryWhat term(s) should one search for on eBay for the basic version of this box (that I assume you modified some)?
You can add a rear output or have it turned around on most PTO'SFinally put the PTO on the trans. Sure do wish it faced rear. Not a lot of room to mount the hydraulic pump. Maybe I'll get the rear winch done this year!
I have (2) of these I'm bringing to the GA Rally for sale. They are brand new and uninstalled. And yes, they are worth every penny.They are worth it, we bought a lot of 20 I think about 4 years ago. The foam is different says my upholstery guy and my backside, believe that it is some of the newer MRAP type foams to prevent spine injury these are the second type seats in the up armored 939p2 the older seats were mounted on a sliding rail that traveled up and down with what we're basically air shocks. And the console is made of aluminum with mounting for a radio and amplifier in the middle section and air conditioning underneath, the top shelf unbolts for easy access to the radio gear, but yes it is meant for a gunner to stand on and the whole thing is made out of 1/4" aluminum very strong.
I wasn't sure of the factory 5 ton winch PTO could be taken apart and reversed. I searched and only found deuce ptos being reversed. The rear output add on is as much $$ as a new PTO. There is a lot more room toward the rear though.You can add a rear output or have it turned around on most PTO'S
So I assume they have 24V lights, or are they 12V yet able to work with 24V?Finally got around to hooking up my license plate LED's for Fluffy.
Got a ticket for not having any lights shining on my license plate in my CUCV a while back, didn't want to repeat that process again, though the man with the black latex gloves was gentle on me, lol.
Pics are dark with no lights, lights and how they look normal. The LED's are mounted in the license plate bolts, in case you're wondering, Autozone or any autoparts store should have them in the license plate section. They are wired straight up to the wire that feeds the tail lights when the driving lights are on, forget what number wire that is, but easy to find with a test light.
View attachment 649640View attachment 649641View attachment 649642View attachment 649643
