simp5782
Feo, Fuerte y Formal
9,499
Mason, TN
Finally got to removing my smashed hard top along with my windshield frame, come to find out it damaged a bit of my cab. So now to hunt down another 939 cab.
South has a rust free one there in Cookeville. Just needs to be taken off.
Sent from my SM-G860P using Tapatalk
simp5782
9,499
Mason, TN
Excuse my ignorance but why are we taking the run flats out? Can they be reused after that 15 seconds or are we throwing them out anyway?
They suck Dave. Your beadlock insert will help you keep the tire on the rim at low pressure. The run flat is good if you are taking debris and gun shots to the tires to get you out of trouble but you only need that in the inner cities. Plus they cause vibration and balancing problems.
Swamp Donkey
The Engineer
123
Gray, GA
My runflats ride smooth. I seem to be the exception though from what I've read.
I left mine in because I'm in the deep woods and on the hills or side slopes a good bit. Some pictures are a couple pages back. A full flat tire down there would likely leave me stuck and it'd be about impossible to change a tire down there, not that'd I'd want to even if it wasn't. Soft ground with no flat areas does not give me a warm fuzzy feeling when a tire needs to be changed on a truck currently weighing 27,000#.
simp5782
9,499
Mason, TN
I left mine in because I'm in the deep woods and on the hills or side slopes a good bit. Some pictures are a couple pages back. A full flat tire down there would likely leave me stuck and it'd be about impossible to change a tire down there, not that'd I'd want to even if it was. Soft ground with no flat areas does not give me a warm fuzzy fuzzyeeling when a tire needs to he changed on a truck currently weighing 27,000#.
You need the weight distribution mat that you can use on soft ground that displaces the weight on the jack and doesnt let it sink.
big block 88
Topeka/Kansas
Mine ride great too. No vibration or shaking.
IMO i want my truck inner city ready in case i need to go in to scavenge for supplies if the shtf. With these anti trump folks we may be on the brink of it any way lol.
Swamp Donkey
The Engineer
123
Gray, GA
I've got the stuff to do it, just not something I care to do. I'd much rather make it to the flat field to swap a tire if I have too. The weight of the truck is one thing...swapping 500# tire/wheels on sloping ground, leaves, rocks, mud is another.
That SHFT talk is going to get us in trouble. Glad to see I'm not the only one who likes them though.
simp5782
9,499
Mason, TN
Replaced my fuel filter. Drained and refilled my transfer case after a 2,000mi break in period. Got the grease gun after my truck and trailer.
Got both of my new mirrors installed.
Replaced my first bypass oil filter at 2,000miles. I will get it cut open tomorrow and check the contents. The oil color has changed a good bit. At 5hrs on it before the bypass it was just pure black. At 30hrs on the bypass filter it is starting to turn back the tint of new oil just a bit.
71DeuceAK
451
Fairbanks, Alaska
Wes, I always enjoy reading your posts, since you drive yours so much! As someone who plans on driving mine I'm getting quite a bit, frankly going for the million miles the NHC250 is rated for, I'm always curious how things actually finally wear out on these!
161
Argyle MI
Just curious where'd you get the mirrors the factory ones leave a little to be desired especially being 6'5". I can't seem to be able to adjust them to not have to bend down to see out them
Sent from my SAMSUNG-SM-G890A using Tapatalk
simp5782
9,499
Mason, TN
They are unitruck #7184. They are convex so they cover alot of area. I got them off ebay for 35$ each. They work on left or right. You can also put them wider out for towing. Part #7185 are 24v heated mirrors.
161
Argyle MI
Thanks.
simp5782
9,499
Mason, TN
I also swapped to LED clearence lamps. I painted them black just waiting for them to dry. 20170130_103557.jpg20170130_103551.jpg
twisted60
251
Jupiter, Florida
Finished installing LED turn and tail/stop light, already installed the side LED markers.
Tomorrow I'll install my new exhaust from TMG, and do a little write up.
twisted60
251
Jupiter, Florida
The rear tail/stop light are Grote LED Brake Lights, I had the lights but needed buckets, 162tcat came to the rescue and helped me out with the buckets. The front are Truck Lite LED amber. All are military style, the Grote's bolted right to the old military buckets.
