MAdams
142
San Dimas, CA
I mounted up 8 16.00R20's this weekend. I had all the wheels, tires and beadlocks pressure washers and ready to go. I got down to 27 min a tire but in this video it took my 32min total. I was having a heck of a time with the beadlock. The video might be boring to most of you but all my friends were asking.
https://www.youtube.com/watch?v=M9zKVrfrf_E
Another Ahab
4,902
Alexandria, VA
Its always like that. The first one takes 3xs as long as all the others!
Swamp Donkey
The Engineer
126
Gray, GA
I added a 5 drawer toolbox to get my hand tools out of the main box. I never liked the idea of a toolbox inside a toolbox, which is what I have had for a while. Having to empty the box to get the lid on the other box open is a bit annoying.
Swamp Donkey
The Engineer
126
Gray, GA
Very nice Donkey, I'd buy one. Great idea.
https://www.amazon.com/gp/aw/d/B000MK5LWA/ref=ya_aw_od_pi?ie=UTF8&psc=1
I've always like UWS products. Made in the USA and built well. I'm not a fan of the Brite-tread on my truck but all the smooth steel boxes I messed with were flimsy and I didn't like how the door sealed on those. Pricey little box but options were limited for putting something with drawers in this spot. My heart skipped a beat when I first hit that shiny aluminum with the wire wheel to prep for paint. It was all better though once the 1st coat of green was applied. :mrgreen:
fuzzytoaster
3,708
Fort Worth, Texas
Got the Eyecon lights installed with some tips from M35A2-AZ. I had planned the setup since I saw the kit but he beat me to installing it. :wink: Anyway..onto the cab liner and HEMTT seats..
twisted60
251
Jupiter, Florida
Started a small project today that lead into a big pain... Had a small coolant leak at the thermostat housing, that started getting worse so I dove in thinking, change a couple gaskets and put it back together, well Murphy was having none of that. Everything came apart easy then I found the problem, 2 sheared bolts that to this point have claimed several drill bits and 1 easyout, they are really in there, so letting it soak in WD and back at it tomorrow.
Anyone have any tricks to get out stuck bolts ?
twisted60
251
Jupiter, Florida
I'll try PB Blaster, I think I have some around here, already bought a replacement easy out, hope I don't snap this one too. Worse case I'll drill hole larger and re-tap, so much for a quick easy fix...
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
Got a welder?
Find a nut(as in nut and bolt) about the size of the bolt.
Weld it to the broken bolt through the center of the nut.
After its not red hot, turn the nut.
The heating and shrinking usually frees up said broken bolt.
Another Ahab
4,902
Alexandria, VA
SO many projects morph into these kinds of nightmares.
I don't believe anymore that there IS such a thing as a "small" project.
fuzzytoaster
3,708
Fort Worth, Texas
Hey Fuzzy
I bet the second time goes a lot faster....
How about swinging by & doing that setup on mine !
Looks really good
Thanks, and no thanks haha. I've yet to wire it and that will be the fun part..
Are those for area lighting, or more like hazard lights?
PS Sure do like your smoker. [thumbzup]
Area lighting, there's also one in the rear below the tailgate.
