Rmtaunton
31
Smyrna, ga
Oh another tip if making a long run just buy 2 gauge jumper cables and cut ends off it's actually cheaper to buy cables than real wire sadly . A 20 foot set of cables cost me 42 dollars and that's 40 feet of 2 gauge fine strand
TechnoWeenie
1,758
Nova Laboratories, WA
Check out your local welding supply shop..You'd be surprised how inexpensive it is, ESPECIALLY if they have remnants, short sections they can't use...
74M35A2
339
Livonia, MI
Took this one for you guys, helmet horns not included. :)
Solder them with the $19 torch to begin with, and not need any on the side of the road.
simp5782
Feo, Fuerte y Formal
9,493
Mason, TN
I bet those 1600's zapped the power.
16.00s arent killer on power down low on a 250 truck. The 395s with runflats are pretty heavy. the front tandem hop goes away with them.
Sent from my SM-G860P using Tapatalk
simp5782
9,493
Mason, TN
Installed the trucklite leds my parts guy ordered for me and some trucklite 07392 floods for backup lights for working on the trailer. I plugged them into the blackout wire since I don't use it but would be better for night time and not running all my lights
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Make sure you hook your front turn signals to the black out leads! If not, you will be blacked-out on the front of your truck. Nobody will see you backing in if they are on the road facing your truck. I had that happen once... ONCE!
bigsix
huntingdon ,tn
Hey got my transmission in and going. I refilled with atf and it is a totally different machine. I would recommend changing the motor oil out and using atf. It shifts smoother and downshifts smoother also.
