zout
155
Columbus Georgia
My rough cut pieces are 3/8ths steel - my cross tube is 3/8ths steel 6"x6" - all the cross bracing gussets are 3/8th steel as well. I do not think they have a class for what this will tote when I am done.
Amer-team
52
Centralia/WA
Helped a friend change a couple tires on his M923A1 out at Brad's. He had a couple of Michelin's on it and needed Goodyears to match the others. Also adjusted his right mirror braces that were improperly installed. The bracket tilted back towards the back of the truck, so much that the mirror could not be adjusted up enough to see properly. Wrapped a few lengths of rope around the top, hooked a come-along to it and the back of my truck and pulled it up into place. Had to take a few raps with the 4 pound hammer on the front strut to bow it, to make it line up right. Worked like a champ.
2mtrucks
col. city in
I installed a (manually operated) dome light. It is dark 14 hours a day right now and I found myself often using my flashlight to locate something in the cab or even to see my battery or starter switch. I also lock up the steering wheel and it was hard to unlock in the dark. Well worth the $10 spent.
zout
155
Columbus Georgia
Kenm - your slacking Bro - no pic of the rack installed ! we're more of a visual type of folks - pics better than words :jumpin:
73m819
328
gainesville, ga.
1---Installed front spade mounts
2---Installed fuel can mount on inner left front bumper for 5 gal. of coolent,
3---Installed venier cable in place of hand throttle, now can adjust RPM down to about 1 incrument if needed, no more to low at one notch and to high at the next notch, the warmer the engine, the finer the control is.
Swiss's m62 got a real nice BIG fuel/water/dirt seperator CAT fuel filter installed.
MyothersanM1
19K M1 Armor Crewman
435
68
Culver City, CA
IT'S BACK...been a while for this thread.
Last week I installed a pair of red lollipop lights. Then I reinstalled a new trailer brake hand valve to include a new front shuttle valve (had to clean the rear shuttle valve...yuck), all new DOT nylon tubing and push-to-connect fittings.
Amer-team
52
Centralia/WA
M923 -Installed spacers under the fuel can carrier so that it is not directly on top of the tool box. This allows for removal of the fuel can strap, so it doesn't rot out. Lubed the door catches and greased the truck except for the zerks between the transmission and transfer case. I need an extension to get on them. Some of the grease fittings still had tan paint on them, so guess that they had not been greased since it was painted.
73m819
328
gainesville, ga.
1--Installed spade mounts and spades on each bed rail
2--Installed water/fuel can holders on the L/R forward mud flaps
3--Installed a set of rear lights on the beacon mount plates
4--Installed fuel can holder on right cab step in front of battery box
5--Rebuilt tow lights/cable, made a pigtail to fit in towed vehicle trailer plug
6--Installed first aid kit on cab back wall up behind drivers seat
7--Working on power divider mod
TacticalDoc
26
Otisville MI
cleaned out my battery box and made a frame for the batteries. Will have all 4 batteries in it. 2 for the lights on my control panel. The other for the truck.
