Swamp Donkey
The Engineer
123
Gray, GA
Both trucks have batteries under seat. Both have gone through a rebuild
The truck in your avatar has a battery relocation box for the passenger side. The batteries would normally be relocated there when the box and the rest of relocation kit is installed. Your new truck has the standard box configuration for batteries under the seat as it was originally issued.
Mos68x
36
Seligman,AZ
Powder coated the inside of one of my rims. I would’ve done all of the powder before mounting the tires if I’d had the time, but I need to get the truck useable again so that means getting all the new tires on first and then worryin about the fresh powder later. I do more updates on my YouTube and Facebook accounts more than I do here, so it might be worth it to subscribe.
www.facebook.com/offgridoverlander
https://youtu.be/tVIGzVke48o
big block 88
Topeka/Kansas
Did you chop up an old slave cable for that?
No sir i purchased a plug from a member here. I didnt want to cut my slaves up.
The supplied eyelets from the genius fit through the head and plug terminals perfectly. Very impressed. Had it on the truck for 4 hours and went full charge and its now maintaining the batts. Superior to the old battery tenders i used to run.
Brutacus
208
Marion, AR.
Hey Big Block, I really like your charger adapter. I was thinking of something along the same lines, but my truck has the older slave "two prong" plug.
simp5782
Feo, Fuerte y Formal
9,498
Mason, TN
They have an adapter for that. I think i have a few. There are some on that shelf inside the door at memphis equipment
Sent from my SM-G935P using Tapatalk
Willyk
Connecticut
For my charger I used a slave cable end and chopped the end off an old heavy duty set of jumper cables. I use the same charger as big block uses a couple of posts above me. The supplied wires that come with the charger are perfect for the other end of the jumper cables to bite on to. I've been charging like this for a year now. Good charger and no problems.
big block 88
Topeka/Kansas
Yep what Wes said. Just run the adapters on the newer style plugs.
and the post above me is good too. I prefer to wire the eyelets straight to the plug so the alligators dont get knocked off.
therooster2001
44
Colorado
For those doing this, they have HMMWV slave connectors that work great on the bay for like $25 plus shipping. Search for J-6362/U.[FONT=&quot] [/FONT]
Mos68x
36
Seligman,AZ
Does anyone have any suggestions for how to get the bead lock in a new tire? Been fighting the last two tires, still got 5 more to go and was hoping someone knew how to do this that wasn’t a real PITA.
simp5782
9,498
Mason, TN
Ratchet strap. Its easiest that when you pull it out of the other tire to compress it down so its smushed being pulled out. The same way you would do a runflat insert.
Or. Two crowbars inside the tire with straps hooked to a truck and anchor point to spread the tire to drop it in easier.
M35A2-AZ
427
Tonopah, AZ
I use a 1" Ratchet strap also. Best if you have two, pull the first strap down as far as you can then use the 2nd strap to pull it down more.
Then just use some tire tools to get it in the tire.
Mos68x
36
Seligman,AZ
Getting it out isn’t the issue lol getting them back in is. Been takin me and a friend near to an hour just trying to get one into the tire.
since I have the crane mounted in the back of the truck I just loop a chain through the insert and lift with the crane and jump on it a little and it just pops out in a minute or so.
