Elijah95
Certified Rookie
1,240
1,215
Georgia
After an inspirational pep talk from Wes saying “there ain’t nothin to it, it’ll only take you an hour!” I declared bull$(1t and decided to change one of the AT2A’s to an XZL with runflat.
Wasn’t too bad, swapped the O ring out on the wheel & valve stem. Speaking of flipping tires, I’m not a big guy by any means at 6’2 175 pounds, flipping a mounted 14.00 XZL w/runflat will just about strain the noodle
Coffey1
499
Gray Court SC
Blake you got it right! Work smarter not hard.
I find every way to not pick heavy stuff up.
Reason: hernia's are not cheap at 30k
And a month of not getting into your truck to drive.
USAFSS-ColdWarrior
Chaplain
6,251
Yea. That's one reason Robert put a crane on his 925 so the big girls can get in the back!
I told you not to tell
Are y'all trying to tell us: "What happens in the back of a 5-Ton stays in the back of a 5-Ton?"
Hmmmm..... God's watching you!
roflrofl
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
roflrofl
Well Robert is riding on those 14.00 Goodyear AT2s so shes bound to bounce out if he hits a good enough bump.
Sent from my SM-G935P using Tapatalk
Buffalobwana
179
Frisco Texas
I love the idea of cranes in these trucks. I’d like to see a better picture of that crane, maybe one in action, even if it’s just extended. And some more details. What kind of crane, what did it come off of, can’t tell much from the picture.
Coffey1
499
Gray Court SC
I will just got time today to mount it to bed.
Have a few things to adjust and soon as it's done I'll post.
It's a IMT worksaver ws65 2 ton crane
big block 88
Topeka/Kansas
Yeah i need to put a small boom in my 925. My truck doesnt have the hoist arm for the spare tire anymore as the NG boys and girls must have backed the truck into a shop with a low over head. Pushed the hoist boom into the cab and bent the crap out of the cab so we pulled the hoist arm off and use it as a flag pull stand. it works great as a flagpull stanchion though.
Amer-team
52
Centralia/WA
Finished the new boots on the M923 and a drivers side tie rod end too. Plus had to replace the rt. front turn signal can. Mine was full of water and heavily corroded. Turn signal works again. Wow!
Mos68x
36
Seligman,AZ
Took my valve off to find nasty problem on the #5 cylinder.
Pivot shaft broken, top clamp half broken, lower clamp half gouged, one rocker arm gouged, and one bent push rod. I’ll have to take the oil pan off and check for chunks of metal to be sure the tappet wasn’t damaged as well.
Mos68x
36
Seligman,AZ
Wow that's awful... was it running under any unusual conditions?
Nope, no abnormal working conditions. I thought I had it fixed after replacing the injectors, so much for that idea. Now I need to figure out where to get new parts without breaking the bank. I still can’t believe that Cummins wants $422 just for the upper gasket set on this motor.
jcollings
421
Jupiter/FL
What kind of miles and hours are on this truck? what are the temperatures low/very cold in your area? and was this a factory or remanufactured engine?
Thank you,
John
Buffalobwana
179
Frisco Texas
What prompted the removal? Poor performance? Sorry dude. That really sucks. Hope you find happier days and less expensive parts ahead.
Mos68x
36
Seligman,AZ
Thank you,
John
Only 15k/725hrs if the gauges and engine are original. Temps have only gotten to 16 at the lowest so far so I doubt that temps are the culprit. No idea about factory or reman on the motor. All I know is that Jeff (CSM Davis) said it was a Red River Rebuild when I stopped by his place to get the cargo bed.
buffalo, this whole fiasco started when I had a fuel knock and a destroyed turbo a couple months ago.
