6wdcummins83
Hudson valley NY
Today I flushed the coolant system and treated with gunk radiator cleaner. Then I changed the oil and filter in the engine, changed the tranny fluid to dextron. Then changed the fluid in the transfer case and all three axles to 80w90 and changed the fuel filter which was very rusty inside. Next will be paint in spring!
Capehenery
Virginia Beach
Finished the rebuild of the Shutter Stat and installed it. Works so far!
Removed and lubricated the heater fan so I can buy some time to find a replacement. Now it works too.
Started to install the fire extinguisher mount but ran out of daylight.
dawico
Lampasas,TX
NAPA sells a replacement heater fan. Be warned though, they ordered mine and charged me shipping to their store. If I had known that I would have had it sent to my house.
PN 655-1320 and cost me $55 w/ shipping. $37 before shipping and tax. You just have to hook up a ground wire, besides that it drops right in.
But if yours works then go with it.
acme66
Plains, Montana
Got it out of winter moth balls only to find the fan actuator was just blowing air to beat the band. Parked it for a few hours and when I fired it back up the fan had fixed itself. Very convenient. I hope to locate additional 'self repairing' components if I can.
Ken
Another Ahab
4,864
Alexandria, VA
Ken
That is a laugh:
- Had a buddy with a VW bug back in the day ("Peace, Brother!"; he was one of the flower children), and his approach to auto wrenching was to "let it rest" when his car had problems.
- He'd back it into his (parent's) garage, close the overhead door, and leave it to sit overnight.
D*****est thing was; 9 times out of 10, that car would emerge fine the next day, and fire right back up!!
Coffey1
500
Gray Court SC
Let's see maybe the thread should say what have you not done lol.
Well here is what I have done so far.
Keyed door locks
Keyed battery cutoff
Fixed Ctis
Coolent filter
Front winch
Painted truck
Installed locking fuel cap
Still left to do
Install go light,back up lights,led lights on front
Rear winch
New cargo cover
Amer-team
52
Centralia/WA
Turbo you sparked an idea. Someone put a thread in about adding a glove box. For those of us running two batteries, why not put it in the unused space of the battery box? That seems like a project for me later this year.
MtnSnow
NSL, UT
Well got couple of things accomplished over the weekend. Got the 923a2 "Beast" through it's annual state safety inspection with flying colors and the tech doing it went over it with a fine tooth comb. But I knew it would so it's ready for the road for another year of shows and what not :)
On the Beast II I tried out a new air intake snorkel for it as the original had been caved in (looked like someone/something had taken a sledgehammer to it a couple of times). I ended up liking the look so I have another setup being sent to me from Amazon (5" ID to 3.5" OD adapter) & Ebay (the 3.5" ID snorkel) In very quick testing I could see that the Snorkel even with it being 3.5" it flows more air than the stock mushroom cap does as the air restriction gauge didn't hardly move when reset with the Snorkel but it was close to 1/2 way with the stock cap after a quick run after resetting the indicator. When the other arrives I will do more in depth testing to include a drive on the highway instead of just in the storage yard.
Oh yeah here is a pic of it.
Of course I will end up painting the adapter and snorkel when this truck gets re-painted. I will also put a tack-weld or move the clamp that held the mushroom cap on over to this to keep it well secured.
Still need to check on the fuel pickup tube on the Beast II.Will need to gather up a few more 5 gallon buckets that I can drain the fuel into (It came with close to a 1/2 tank or more) so I can move the tank out far enough to pull the tube without bending/destroying it and then get the replacement or fixed tube back into it without screwing it up. I'll also plan on double checking the fuel sending unit as it gauge is always reading FULL even though I know that the tank is currently at about 1/2.
dawico
Lampasas,TX
View attachment 548086 View attachment 548085
I am sure that it breathes better with the cap facing forward. I would have to test it facing backwards just to keep bugs and stuff from flying right into it. The screen seems a bit big to let stuff fly right in.
MtnSnow
NSL, UT
Not to worried as I have an air sock aka pre-filter that can be slipped over it... but if conditions really are that bad it's easy to turn it backwards or to the side. If the big OTR trucks can run them facing forwards without a sock and I have run them forwards on the tractors and such on our family ranch for years without issue without a sock I'm not worried. :)
MtnSnow
NSL, UT
I wanted it to go on the outside to eliminate puddling of water/snow. As for Height I will eventually cut off a few inches from the main pipe to bring the overall height down to the stock setup height.
That Prefilter you picked up should flow much better than the stock Mushroom cap as well.
