Snowtiger
- 1
- 0
- British Columbia
Just checked it out, thank you very much that looks like exactly what I need and a great price even in Canadian Pesos's (lol).
The other post on the switched side goes to the 24v source. Got my 24v source from wire 460-461 off the light switch, which I figured out thanks to The HUlk's post on brake light issues. I put a 15 amp blade type fuse within inches of the 24v connection at the light switch.
The coil is what was necessary to run on 12v. Then for the 12v source, I ran a wire off the first battery's positive (using battery ground as the starting point) straight to the transmission switch. I knew this was a reliable way to get 12v because that is what BMY did to get the 12v source for the heater's low speed). I installed a 10 amp blade type fuse within inches of the battery post connection even before the wire could get near the battery bracket. The other post (blade) on the transmission switch I ran as the positive wire to go to the relay's coil (to activate the points inside that I am running 24v through). The relay's coil negative I just grounded to the dash. I just wire tied the relay to the bundle of wires already wire tied into a ball up under the dash before I got the truck. I think this is pretty safe as the two lights and the alarm sure arent using the 75 amps this relay is rated for, and having a fuse inline as near to each source of power as possible before a wire could even get near the ground. As long as the relay's coil is only getting 12v, plus the 12v transmission switch only getting 12v all should be well and last. One must be aware that a lot of relays aren't fully seperated inside as this heavy one I used is. So it is probably best to just get a 24v relay if you don't understand electicity so well.
This conversion is on my list of things to do, possibly next weekend. I've heard it's a real PITA to get the engine primed once you've made the changeover. What did you do to finally get it primed?Finally got my spin on fuel filter kit on. Priming was a pain but it now works fine. My M923 has a metal line from the tank to the OE filter assy. so I chose to leave it in place and use it to strap the new rubber hose to. Only took about and hour to install.
View attachment 582579View attachment 582580View attachment 582582
Took her to a "Touch a Truck" event for a local fund raiser. Just a note, if you attend one of these events keep the kids out of the cab as possibly the emergency engine stop will get pulled and not seen by the owner making for a difficult start situation. Don't ask how I know that!
I'm guessing that you read about it somewhere in a magazine, is that right!?
. Actually it said "parents keep an eye on your kids when they are in someone else's truck"!I put compressed air into the fuel tank to help get the fuel to flow. You need to plug the tank vent too.This conversion is on my list of things to do, possibly next weekend. I've heard it's a real PITA to get the engine primed once you've made the changeover. What did you do to finally get it primed?
Thanks...
Mark
Isn't that the easiest place to put the air in through? Rubber tipped blow gun to the vent?I put compressed air into the fuel tank to help get the fuel to flow. You need to plug the tank vent too.
Yep....Pull the vent and apply around 5psi with bleeder screw open on the IP and in a minute you will have a bleed system that is ready to go.Isn't that the easiest place to put the air in through? Rubber tipped blow gun to the vent?
Supposedly nothing aftermarket fits (NAPA/Wix, etc....), only the OE filter fits the can, and is not low cost. Some people are buying a smaller OD filter which is available in the aftermarket, and it is believed to flow more air by better exposing the entire surface area of the filter element. Yet to be proven by data, but seat-of-the-pants dyno stories are saying it makes a difference. This smaller OD filter requires a wire "basket" to hold it centered in the canister. Those Military Guys sell the entire kit, or just the wire basket. I can measure this filter dimensions when I get home from work today for you, as I have one not yet installed (but my truck is at a buddy's house for painting, so I can't measure the OE filter for you, sorry, he won't let me at the truck till the paint is done, for wow effect).I want to purchase a couple of extra Air filters for my M923A2, and of course I am out of town when I discover these filters. Would anyone be so kind to post the dimensions of the filter, ie. Inside diameter, outside diameter, an length. its been an expensive week with all the stock piling of lubes and filters and parts. Shes a happy truck
OK, I feel dumb now as I never thought of that.Isn't that the easiest place to put the air in through? Rubber tipped blow gun to the vent?
Where did you get it? Fairly costly or relatively affordable?Finally got my spin on fuel filter kit on. Priming was a pain but it now works fine. My M923 has a metal line from the tank to the OE filter assy. so I chose to leave it in place and use it to strap the new rubber hose to. Only took about and hour to install.
