What have you done to your CUCV today/lately? - Part 1
Atwater
barker, new york
finally put that gooseneck hitch to good use. 1st 2 pics were the day after getting home from our local old fashioned farm festival. last pic is roughly 2300-2500 lbs of weight for the pulling tractor i bought in july. im thinking the trailer may need to be painted to match the truck.
edpdx
80
Oregon
Installed new Sylvania HB (BRITE) type headlights. The Adjusters looked to be OEM. 2 were broken, one was a 1/4" nut /bolt combo, The "last one" was a cap from a marker pen?!?
Got a couple sets of the help replacements- I hear they suck; but I guess I'll see.
AceHigh
31
Lake City FL
File this one under "what is the chance of this happening?"
Bought a M1009 a few weeks ago and just got the license plate today. License number 1009! I am very pleased.
ParamediCUCV
Asheville, NC
Just installed some Ranchero shocks, transmission cooler, and fog lights; replaced the front brake pads, and cleaned the rear drums to get rid of that awful squeaking. Now my M1009 rides like a dream!
SPCWarning
11
Stonewall, MS
.....just got in from work Friday night, was out tinkering with the 1009 this morning before Church. The Blackout Drive light wasn't working, all the Blackout markers were fine. I decided to just remove the cover on the main drive light...........IT WAS COMPLETELY FULL OF MUD!! I cleaned out the mud, surprisingly the bulb was still in place, blown of course, but it came right out. The socket seemed to be in perfect shape considering it was submerged for who knows how long. Found a small crack in the lens, temporarily patched it with clear high temp silicone, checked the power, all ok..........just gotta find a replacement bulb. It looks a lot like an 1156 bulb. Anyone ever tried one in the Blackout light? If not I'll be searching for the original replacement bulb.
........Soon to come: doghead relay upgrade
Disciple
Eagan, Mn
Installed a light for the rear license plate (State Trooper's "Recommendation"). Replaced front rotors and brake pads, packed bearings, extended rear diff breather tube, replaced heater core, installed my lift kit and tires. Next up: install removable rear drop-bumper to meet MN's 25" max bumper height (also a "recommendation" from our local finest).
Hightechken
NE Wisconsin
I used an 1156 bulb in a plastic housing BO light and after some use the bulb ran hot enough to start melting the plastic.......... (It WAS nice and bright)
So if you have a plastic lens set up, Be careful of heat from a replacement bulb.
chief1983
Saint Charles, MO
Took the Blazer to an offroad park near Salem, MO (not trailered, just drove it down). Wanted to watch the big rock crawling rigs tackle some obstacles at an overnight event. Decided to try some of the easier trails, and they weren't that easy for a full size. Broke my rear drive shaft, had to patch up the transfer case with a pop bottle and drive over 100 miles home in 4 high with no rear drive shaft. Apparently this happens all the time in the offroad world. Also blew the front hub seal, so I've got plenty more work to do.
jets1959
9
Lakewood, WA
Don't know where I left off so I will start at the begining. Replaced all six u-joints, brake shoes and pads, turned rear drums, replaced front rotors, replaced injecter pump, replaced vaccum pump, did doghead relay mod, replaced all king pin parts including the top pins, replaced all the steering linkage, changed the glow plugs, greased all the grease fittings, replaced all shocks and steering shock, repacked all wheel bearings, had to replace front wheel bearings, serviced front and rear axle, serviced trans. and transfer case, installed high capacity aluminum front and rear dif. covers, installed aluminum trans. pan,installed front and rear trailer hitch, installed trailer brake controller, installed aux. heater in rear box from an 1980's Chevy van kit, installed solar powered trickle charger, installed bf goodrich mud terrain tires, installed cigarette lighter in ash tray to charge cell phone or gps, changed out drivers side tail light assy. to have license plate light, installed 2002 chevy med. duty license plate bracket behind left tail light using studs in tail light assy. just like it was made for it which it was, replaced all heater and radiator hoses, replaced radiator recovery tank, flushed and refilled cooling system with prestone long life antifreeze, replaced wiper motor and wiper blades, replaced windshield washer jar, installed fire extingisher in cab next to transfer case shifter where one was suppose to be, replaced harmonic balancer, replaced door locks the ignition lock was changed right before I bought the truck none are millitary key coded, installed mud flaps in rear, replaced all vacuum lines, replaced fuel and air filter, changed the oil and filter three times so far, replaced oil fill cap, repaired the only rust out area on the drivers side rear bottom cab corner, patched holes in box roof where rotating lights were removed before I got the truck with one foot square aluminum sheet looks factory, and installed locking lug nuts. This is all since April when I bought the truck. This has not been an overnight process. Good luck to you all with your projects. Mine is not done yet either.:driver:
greg6459
D/FW TX
Trailer
Yes. A repaint would complete this quite nicely.
