Cucvnut
- 75
- 48
- Carver, Oregon
fixed my IP. installed the stupid missing part.
I just received my Grill Cover for the Blazer from Jatonka. Dennis included some instructions and it looks to be a breeze to install. I'll post when I do...
I've thought about fitting a lock cylinder, but I don't want to cut a slot on the fuel filler surround for it to engage... I may have to fab up a plate / tab for it to hook to.HoJoPo, Do u have your converter lockup controller hooked up? I have mine setup to lock up in 2-3-4, It seems to run better. For your fuel door, get a lock cyl off one of those key lock boxes. Putting a lock and hasp would take away from that trick looking door u installed.
Haven't done it yet...
But I will be taking the front wheel off and checking the tire for a leak... the **** thing is flat
Either way I found a set of the same BFG MT's on CL for pretty cheap...so hopefully the guy still has them if my leak is not fixable...
Nice setup you got there! I've been trying to water my 1009 but it won't grow that much.swapped in a dropside bed and installed a custom built receiver hitch the other day so i could take my homes away from home with me.
Pictures of your HMMWV intake/airbox setup would be great. I have been thinking about that as well along with a snorkel.replaced Ip pump installed new valve cover gaskets. Installed hmmwv intake and intake horm, New air box, Rewired glow plugs to manual switch my system was not working correctly.
