What have you done to your CUCV today/lately? - Part 1
twa@ezdn.net
19
Chesapeake, VA
Wazzup Tim,
I like your ride height and tire/wheel setup. Can you elaborate on the size tire you are using and specs on your suspension.
Mahalo's
M1A96819
Hi, The tires are Goodyear MTR Kevlar 35's the lift is four inch with a add a leaf and block in back and new springs up front. I had Pungo off road do the work. Just finished my roof rack.
Thanks Tim
UncleSam
Anniston Alabama
Fender, Door & Hood
Replaced my right front fender and door and hood. Replaced the window regulator in the door, I don't know who designed that door but they should be SHOT!!!!
There's got to be an easier way to replace a regulator..aua
:rant:
UncleSam
Anniston Alabama
This pass few weeks I've added new GP Module and I've got to say that " LIFE IS GOOD!!! Iv'e cleaned up some wiring thanks to Warthog and doghead help, Thanks guys!!!
My M1009 runs so much better amd starts a lot easier, and also my gauges and light are working again, and my fast idle sol is working again
I've changed out my right door, right fender, hood and grille and front trim and headlight trim and mounts.
My brush guard is bent, has anybody had any luck having these straighten out?
I've posted some before & after pixs.....:hammer:
DrJekl
Clarksville, TN
I put a crack in my transmission about 4" from the rear that ran between the governor cover and the plug where a 2WD speedo gear goes. Built a new one and swapped it out. Good times!
chief1983
Saint Charles, MO
Disassembled and fixed (I think) a stuck vacuum regulator valve. The metal parts inside the valve are a bit corroded, so it might not last long, but it was stuck fully open. Now it closes properly when throttle is given, although it might be off still. Figured it was worth trying it out, to see if I can save $75.
acesneights1
21
20
CT
Did the Doghead relay mod. What a great sticky.
Also I beat the balls of it at a mudbog and set Gen2 on fire washing it...[thumbzup]:mrgreen::driver:
combatmech
Carrollton, Texas
R&R'd engine fuel pump, ( now I see why guys go electric ) all four shocks ( M U C H better ride than before ), and a stretched out Gen2 belt.
Ready for a road trip!!!:beer:
rjinga
Monroe, GA
Starting Friday evening, off and on through this evening, I sanded, straighten, and painted the bumpers and brush guard with Rustoleum rattlecan bedliner, replaced the carriage bolts holding on the brush guard, removed the euro fog lights and replaced them with driving lights.
maetl
Bend, OR
That's a sharp looking truck. I've been considering redoing mine in white someday. Any way I could con you into posting more pics of yours?
Thanks
