Mainsail
1,801
Puget Sound, WA
So I attempted to do my front brakes and overhaul the hubs and lockouts. Ended up having to replace the hub bodies and the bearings. They looked pretty rough. Then noticed that the threads on the spindle were pretty messed up, looks like the anti-rotational washer cracked, spun and took out a few threads. Also found the front u-joints loose. This weekend got expensive really quick.
I did my front brakes a few weeks ago and it went pretty smoothly. After reading that I'm glad I never looked at anything else.
FatBuddhaBoo
Jacksonville, Fl
Installed new rear window rubber seals, removed old driver and passenger side window seals to paint those areas prior to installation of new seals, busted drivers side wing window while trying to open it, and modified my original lighting configuration to get my dash illumination and running lights working.
Hiram
Ohio
Installed heavier rear springs, Bedlined the driver and passenger footwells and door sills, changed the oil, moved the 2M radio to a floor stalk mount, replaced it's overhead position with a fan.
I_Publius
Prosper, TX
I am finally frustrated with my truck. Today I drained The old diesel and replaced it with new.
I added two new group 31 batteries (Blemished from a large battery manufacturer here in Texas for $40 each)
Attempted to start her again and nothing.
I did get a nice electrical burning smell inside the cabin, however.
Glad this is not my daily driver.
CAVman
Indiana
20130812_142723.jpg20130812_142733.jpg Stripped the M1009 to get it ready to be lined. Anybody know what those cables in my bed might before? All I can tell is it might be for a CB radio?
Durango_USMC
Indianapolis, IN
Well what are they hooked to? Seems like they go towards the antenna and a power block on the wall where the radios used to sit? I'm really not familiar with the M1009's though so I could be pretty wrong that. Have you checked the TM's? I recall seeing something in I think the 34 about the radio wiring in the M1009 for the comm systems.
True Knight
183
San Pedro, CA
Installed some new longer front brake lines. Going to replace the rear too. And I found that there is something binding in the steering, so now I have to find out what's causing that. Good times.
