- 4,429
- 3,713
- 113
- Fort Worth, Texas
Where did you pick up that bad boy, fuzzytoaster?!This just in.. M1148 (though technically a M1148A1R). Pretty dang rare. I'll get into it next week to see if she will fire up. No fuel, bad batteries, etc.
Nice score, did you experience any issues with the stock turbo? I don't want to kill my stock turbo running the 370hp tune, but I'm assuming the liquid cooled turbo would only be needed when operating at the extreme end of the performance envelope.Not what I have done to my 2008 M1078A1R, but will be doing now that I have finished my complete restoration of the C7. As all of us running the 370/931 tune know, the only difference between our C7's and the 370HP variant in the Stryker is the water cooled turbo, CAT part# 290-4044. Just picked this up brand new, not a reman, for $1000. It's a little over $4000 new from CAT.
Yikes. $4K seems pricey.Not what I have done to my 2008 M1078A1R, but will be doing now that I have finished my complete restoration of the C7. As all of us running the 370/931 tune know, the only difference between our C7's and the 370HP variant in the Stryker is the water cooled turbo, CAT part# 290-4044. Just picked this up brand new, not a reman, for $1000. It's a little over $4000 new from CAT.
No issues with the stock turbo. The C7 in the stryker is crammed into a very tight armored compartment so cooling is more of an issue. It's also way heavier than our trucks and designed to operate in a climate where ambient temps north of 115+ degrees aren't uncommon.Nice score, did you experience any issues with the stock turbo? I don't want to kill my stock turbo running the 370hp tune, but I'm assuming the liquid cooled turbo would only be needed when operating at the extreme end of the performance envelope.
I converted my '98 3116 to a watercooled CAT turbo. Made my own lines.Yep. The coolant lines for it are the fun part to track down. CAT can get them though some are special order and you have to wait for them to make you one. The M-ATV is actually the 370 HP variant of the C7, and the more common source - over 10,000 have been built. The Stryker uses the 350 HP variant and less than 5,000 produced.
I think that turbo is closer to $4500 from CAT. I also found one new old stock surplus for $450. I have yet to install it but I have all the parts to do so. I've got a friend with an M1088 based overland rig that has the complete M-ATV crate engine with water cooled turbo in his truck due to a cracked cylinder on the original engine.
I found them in CAT SIS without issue. My experience with my local CAT dealer is if they don't have the hose/line in stock, they make it while you wait. That said, a line with a section of shaped hardline would need to be ordered. I'm hoping the coolant line for the water cooled variant doesn't use the outlet on the thermostat housing that the heater hose is connected to. Don't want to rework that as well.Yep. The coolant lines for it are the fun part to track down. CAT can get them though some are special order and you have to wait for them to make you one. The M-ATV is actually the 370 HP variant of the C7, and the more common source - over 10,000 have been built. The Stryker uses the 350 HP variant and less than 5,000 produced.
Is your cab on square? The hooks are bolted on under the cab. Mine are symetrical on my arch guide pins, but my cab is rotated ~1/2” toward the left at the rear, so I need to make a little adjustment…Just have one major problem to solve: where the hooks on the back of the cab should ride on the pins on the big hoop, one fits right, the other hook won’t fit. Will get pics another day and post as a new thread.
Wandering Neurons, brother, you are FEARLESS to have undertaken such a project; you GO, Man!!Long story made short. The cab of my M1081, Goliath, was bent, mostly the upper half, from a partial roll-over. Wife’s bedless truck, and a beauty shot of yesterday evening’s rainbow with my horse Gus.
PS I have seen my fair share of Rainbows, but do not believe I have ever seen a full semi-circle Rainbow like that one you caught .
That flat open plain territory of Nevada might be part of the reason.
Brother , you sould copyright that image, and market it. That is a killer shot!
