What have you done to your HMMWV today/lately
TOBASH
3,987
Brooklyn, NY
It's way cheaper than led complete lights. And looks just like stock. I went with cheap hella knockoffs that didn't fit then purchased the real deal. $35 a piece from Amazon.
HELLA 002395031 HLMP 7" 165MM H4 ECE,2395031 https://www.amazon.com/dp/B005OULUQO/ref=cm_sw_r_apan_i_ET1DACXFCW0X5QN4F5WG?_encoding=UTF8&psc=1
Any h4 led bulb will work, all you need is h4 pigtails to match up with the factory wiring. You can cut wires off old bulbs!
In the listing for led h4's they will show you voltage range. I used these and they are perfect and cheap.
Limited-time deal: OXILAM Mini Size H4 9003 LED Headlight Bulbs, 12000LM Hi/Lo Beam Wireless 6000K White Super Bright LED HB2 Bulb for Car Motorcycle Conversion Kit, Fanless Replacement Bulbs, Pack of 2 https://www.amazon.com/dp/B09HS7499B/ref=cm_sw_r_apan_i_dl_HF50QA15DWDETDSMMCFE?_encoding=UTF8&psc=1
Pretty affordable awesome option!
tgejesse
289
Maryland
I tried to tell the sideways led epay seller that the light is not for hmmwv. They disagreed with my opinion. Now you see why it isnt fir hmmwv.
I knew it wasn’t. I bought it because it was the only one on eBay and I knew it’ll work. My old one had the words painted over anyways. Sideways or no words at all. This will work for now. The wait light was much MUCH more difficult to get out.
Milcommoguy
2,431
Rosamond, CA
It's for hard braking and coming to a stop sideways, CAMO
TOBASH
3,987
Brooklyn, NY
Caactus, I’m late to the party here and I haven’t caught up. ( If I’m asking a dumb question, that’s my excuse and I’m sticking with it!) You sure the IP isn’t leaking. ?
Caactus
209
33
NW Phoenix, Arizona
I’ve had a few hoses split before or after the filter. OR the clamps got loose. Plus a pesky fuel drip when I filled it up all the way that turned out to be a really loose connection at the tank. Still smells a little diesel-ly in the cab but Arizona is blessed by windows open (or doors off) weather most of the year.
Crapgame
343
Navarre, FL
I've been looking for a solution like this for awhile, just for the safety aspect instead of the GI 60w incandescant bulbs, thank you.
