- 1,425
- 1,458
- 113
- Puget Sound, WA
Instead of wondering what kind of amperage is running down Wire 14 I decided to find out. I talked to a techno-wienie I know (Technowienie) and he was skeptical about the 14ga wire carrying 70 amps. Also, whatever switch I use, even if the contacts weld themselves together it's not going to cause any drama, because the welded contacts would then be doing what the neutral switch is already doing in Park or Drive.
So here's what I got, 5.25 amps max when starting. Repeated it five times, same result.
Next up was getting the piece of ducting replaced. I really don't know what this does, since even with the fan blowing I didn't feel any air blowing out (or in) the open ducts under the hood. But it's supposed to be there so I ordered a new one. Now I know why they don't replace them, big drama and lots of grief getting that stuffed in there. That took most of the afternoon.
Replaced a missing zeus spring for the doghouse- I found the old one laying on the engine when I got the truck home. Drilled out the rivets and riveted in a new spring.
Last I got the shelf roughed in. I want it to be tool-less but I didn't feel like running out for hardware so I used what I had in the vast stores of collected crap.
So far, this is the collection of stuff I've found inside the truck. The fire extinguisher pin makes me a little nervous...
