What is the SAE bell-housing size for the 8.3 and 250?
WillWagner
2,401
Monrovia, Ca.
Give me an engine s/n and I can tell ya. Most likely a #2, but give me a s/n to make sure.
WillWagner
2,401
Monrovia, Ca.
This is for the NHC, p/n 3014979
MR - HOUSING, FLYWHEEL...(More)
Engine Family: NHC-250
SAE #2 Wet Flywheel Housing
With Offset Mounting Arms
Can be Used With Small Cam
Engines Only
For Use on NHC-250 Engines
in M-809 and M-939 Army
Trucks - Not to be Published
ScubaCat
Olean NY
Engines Only
Thanks. Wondering if the 8.3 is the same. Would love to put a 8.3 in my 818 and keep the 5sp...
ScubaCat
Olean NY
Just saw one posting that had a pdf saying the 8.3 is a SAE#1...What I dont know, however, is if ALL the 6cta engines were #1s....
ScubaCat
Olean NY
Thanks guys, with the specific title of this thread, this info should be more easily found in the future should someone search for it.
Csm Davis
376
Hattiesburg, Mississippi
Below are pictures of the 8.3L bellhousing out of a M939 series truck. 12 bolts on a 18.375" bolt circle is a SAE#2, confirmed.
G.
So are the mounting arms offset like the one for the 250? In other words are they mounted in the same place? I know that they are different as the starter is mounted different.
Sent from my SM-G900V using Tapatalk
