What is this?
usmc320
RVA
I found several strips of this in the engine compartment the other day. One was on the left side of the engine, one on the right side, and some pieces of it on the air compressor. It looks like something that would come from a radiator, but I couldn't find any damage anywhere. Anyone ever seen this or have any ideas where it might have come from?
11Echo
96
CT W. R.
Take a look around the outer edges of your radiator core. Sometimes the cooling fins in an old radiator start coming out from between the cooling tubes.
3,164
That is part of the radiator, you need to go look again ,carefully. Those are the "fins" that are between the rows of tubes. It's gonna keep peeling out.
usmc320
RVA
Thanks everyone. I'll take a closer look around the radiator. That's what I thought at first too, but didn't see anything the first time and didn't seem to be losing coolant or anything either.
1stDeuce
Mancos, CO
Yeah, that's from a radiator. Those are the fins that go between the tubes, accordian style. It's possible they're from an old radiator that got replaced if you're opening the hood for the first time since you got the truck, but more likely that they're from the radiator that's in the truck right now. Look for missing fins between the tubes... I bet you find air gaps where they should be... Note that if this happens much, the radiator is really going to loose efficiency. :(
C
11Echo
96
CT W. R.
Just to walk up to this truck you might think the radiator is ok. If you look /lean in there you can see the developing problem. The cooling fins on both side, outside rows are out and missing or will be soon. This radiator was not leaking and the truck ran fine.
11Echo
96
CT W. R.
If the cooling fins are only coming out from the extreme edge of the core my radiator shop says they can sometimes fill that in with rubber inserts to keep pressure on the middle saving the radiator.
