What jack stands do you use….. looking cheap….
ramdough
1,727
Austin, Texas
I am needing to pull my front right bring perch nuts off to swap my lower cab tilt piston mount.
I have several 6 ton jack stands, but that feels like they need more safety factor for holding the front end. (And they are too short to reach the frame).
Anyone have a recommendation for taller and maybe stronger stands?
BKubu
1,088
Gaithersburg, MD
I use military 7 ton jack stands that are made for big trucks. I don't have them handy to tell you the brand. I feel that a 6 ton jack stand is sufficient, especially if you are only removing one wheel. If you want additional safety, leave the jack underneath the axle, too (or use both 6 ton jack stands). With all this said, if you are buying some, the higher the rating, the better!
19,071
Remember, you under the truck smashed like a bug is a really bad day.
7 ton stands under the front axles get you the height that you need.
You could also spend the time and effort to block the truck up with wood.
ramdough
1,727
Austin, Texas
So, I plan to leave the tire on the ground….. but I do need to support the frame since I am loosening the front spring perch, removing the nuts, then swapping the cab flip piston mount.
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
Go get a 6x6x10 each block is 6 blocks cut at 18in each.
Or get a railroad tie and cut it up.
Cribbing is always more useful than a jack stand
chucky
18,745
TN .
Like simp said you cant go wrong with 6x6 or 8x8 blocks if you remember i put my whole truck in the air when i swapped the back 4 tires they lived there for 2 days with the wind blowing on the box ! Cant you use a few big c clamps to hold it in place during the swap ?A1002B66-E733-411D-8ED2-68C818462EE0.png
kblazer87
305
southeast Indiana
One other point...most jack stand ratings are for the pair. Keep that in mind.
Not all stands have always been rated in pairs. A lot of the older ones you will find for sale used, were rated as singles. All of my heavy duty stands are older (made well before 2015) , are rated per stand and are U.S. made, good quality stands.
2015 is when all were mandated to be rated in pairs.
BKubu
1,088
Gaithersburg, MD
I am glad you pointed out the mandate in 2015. I had no idea about that. I will add that I have a pair of heavy duty jack stands that I bought 25 years or so ago that were rated in pairs, too. I am unsure when they started that. My big point was that a person needs to consider that they could be rated in pairs, not singly. I know I did not know this originally. I thought a jack stand could handle four tons when each were marked that way. It was misleading, at least to me.
BKubu
1,088
Gaithersburg, MD
One more point...those four ton jack stands that are marked as such do not specify anywhere on them that the four tons corresponds to the rating of the pair. It was on the paperwork I received when I originally bought them. Making it even worse is that I only have one at this time. The other got pancaked by an M543A2! It started to rain, so I pushed the jack stand under the truck and forgot it was there when I drove away! Doh!
kblazer87
305
southeast Indiana
True. Note that I said "most jack stands," not "all." I see you said that they mandated this in 2015. I have no reason to doubt you. However, I know jack stands I bought over 20 years ago were rated in pairs, too.
Agreed. I have 2 smaller pairs I use for cars, mowers and such that are close to 30 years and also are rated by the pair (walmart) I think it was at manufacturers discretion prior to the asme standard.
Just buy a crane or two
I'm working on it. Not many that fit in a tight ass's budget though.
simp5782
9,260
Mason, TN
You wouldn't think but a 7.5 to 30ton unit can be found under 6k.
Third From Texas
6,327
Corpus Christi Texas
No way to put the genie back in the bottle now, just assume all stands are rated in pairs, unless you can prove otherwise. Another reason to use good cribbing…
It is a fact. The ASME rates stands "per pair" (or at least have in recent memory).
"Jack Stands made after 2015 are always rated as a pair. Meaning 6-ton jack stands are individually rated to hold a maximum of 3-tons. They are also only rated when used as a pair together."
Oddly, some companies make this hard to discern in their instructions/manuals/safety info. This is what's in the Harbor Freight Jackstand safety section
"Maximum load capacity per identical pair shall not exceed the rated capacity of the individual stand."
That sorta says the same thing, just a bit backwards. But the pair still share the same load rating (ie: it's not doubled by using two).
Further looking around, I found how the ASME rates them (which is a wee bit conflicting to what they state above):
"to meet the standards set up by ASME each jack stand must be tested to 150% of the rated capacity of the pair to pass. Therefore, a 6-ton rated jack stand pair each individual jack stand would be tested at 9-tons. As long as the jack stand doesn’t fail at 9-tons on a single jack, then the pair passes as a 6-ton jack stand with ASME certification. "
Now I wouldn't bet my life on that, so I'd stick with keeping then within operational spec.
I have the 12t Horror Freight stands. Heavy mofos and I trust them (as jackstands) when set up properly. But I always inspect the welds and pins, etc before deploying them. Interestingly (and not shocking) some old stands that HF (and others) sold have been recalled over the years. So older isn't ALWAYS better/safer. But I trust their more recent models.
Here's quick little page I found on the web that kinda confirms most of what's been said here....
* @ramdough : note that they recommend avoiding "cheap" ;)
