What wheels are on your humvee?
nikojo
105
Wisconsin and Illinois
kungflu72
Ohio
New member, frequent lurker. Just hoping to keep this thread alive. I like checking out other rigs. Some really cool builds. Im running stock 24 bolt wheel/tire combo. Blasted the wheels and raptor lined them for durability. Hindsight being 20/20, I should have put balancing beads in them during the rebuild.IMG_5562.JPGIMG_5566.JPGIMG_5572.JPGIMG_5562.JPGIMG_5566.JPGIMG_5572.JPGIMG_5562.JPGIMG_5566.JPGIMG_5572.JPG
Elijah95
Certified Rookie
1,245
1,220
Georgia
New member, frequent lurker. Just hoping to keep this thread alive. I like checking out other rigs. Some really cool builds. Im running stock 24 bolt wheel/tire combo. Blasted the wheels and raptor lined them for durability. Hindsight being 20/20, I should have put balancing beads in them during the rebuild.View attachment 833250View attachment 833251View attachment 833252View attachment 833250View attachment 833251View attachment 833252View attachment 833250View attachment 833251View attachment 833252
You can air down and use 50/50 coolant to balance them, safe, effective, will not corrode or damage wheels or the O-rings
Coug
4,754
Olympia/WA
50/50 coolant...please explain...
antifreeze.
It's designed to be rubber safe as well as non corroding to metals.
I don't think it has to be mixed, it can be straight antifreeze since you aren't looking for heat transfer ability in this application.
The only real downside to using antifreeze is it soaks into the rubber just a little, and you can't put a patch in the tire later if you get a small hole in it.
Elijah95
Certified Rookie
1,245
1,220
Georgia
antifreeze.
You nailed it! Except I don’t recommend 100% because it’s prone to freezing and it is corrosive. If you buy a jug of 50/50 “premixed” you’re good to go
Duff ace
FL
So I got the new air lifts that are 2” higher to accommodate the future lift.
I haven’t taken possession of the 2003 m1123 yet but I’m afraid if I go with the black rhino 20x9.5 arsenals with a -18 offset and Nitto grapplers at 38x13.5x20 that they would look too small with the 2” body + 2” suspension lift.
If I forgo the lift then I have these extra high air lift hooks.
thoughts?
Gamble
375
Los Angeles, CA
thoughts?
I just got a 2in susp lift plus 2in body lift for 40inch Nitro Mud grapplers
LouWon
103
Michigan
I had posted this earlier
I got the Black Rhino Arsenal 20 X 12 with the -44 offset, Nitto's Ridge Grappler 38 X 13.5, they have the beads for balancing, nice and smooth ride.
With the -44 offset, they just stand out a bit more than the original wheels & tires
I did upgrade my suspension, American Humvee coils, Cepek adjustable shocks, the only problem I found is that with the softer coils, the front end went down and I did do some dammage to the fenders, I added the coil spacers and id made a big difference. I also removed the sway bar, this is not a race car and you get more flexibility without it. No body lift kit, plenty of clearance between the tires and fenders
Coug
4,754
Olympia/WA
Do you have any lift on your truck? I have a stock height H1 2001 and want to put the same size tires
Those 38" should fit no problem, stock is 37"
You might not be able to run full size tire chains with them though, if that is a concern.
If your suspension is good (and it's not uncommon for the springs to sag on these, so check them), you can do up to 40" tire without a lift.
The reason for this is the stock tires at 37" have enough clearance to run with tire chains. The tire chains will add about 1 inch to the tire every direction, which effectively adds 2" to the outside diameter, making it 39"
Action
1,564
East Tennessee
And leighread7 also has a 1/2” body lift on his 2001 H1.
