whats in your gas tank?
1,806
Right now my M108 has a conconction of diesel, WVO, used filtered motor oil and used filtered tranny fluid. Umm, good stuff!
oifvet
9
(near) Xenia, Ohio
For now, until I have better means, I just run commercial grade deisel with Lucas Oil Products fuel stabilizer additive.
saddamsnightmare
80
Abilene, Texas
March 27th, 2008.
Currently my M35A2 is running 80+% Diesel, 18% regular unleaded, 2% Rotella 15W40 (used), and is seems to like the rotella better then the low Sulpher No.2 diesel straight. When running diesel only I do add Cetane enhancer and stabilizer, and she usually starts at below 32*F in less then two revolutions. If I could locate a legal source of ATF used, I'd be on that in a heartbeat to cut the rotella further.
Sincerely,
Kyle F. McGrogan
1971 Kaiser Jeep M35A2 Wo/W "Saddam's Nightmare" Desert STorm and Vietnam Veteran Deuce
""??"" M105A2 Johnson MFG Co. 1-1/2 Ton Cargo Trailer, MERDC or NATO 4 color Woodland scheme
1963 Swiss Army Cargo Unimog S404.114 Mercedes Benz, NATO green
sermis
17
Temple, TX
Gas, old gas, diesel, 20 year old diesel, power steering fluid, auto trans fluid, used motor oil, mixed boat 2 cycle oil / gas. That’s all I can think of right now.
BKubu
1,119
Gaithersburg, MD
Pretty boring...I use only diesel and fuel conditioner only. Does using the other fluids (brake fluid, motor oil, etc.) cause you to need to change your fuel filters more regularly?
sermis
17
Temple, TX
I noticed when I add diesel fuel conditioner I get a lot of gunk in the primary filter and clog it up. I have an old propane tank that I mix everything in and then double filter along with water separator and then put it in the truck.
I found a source for used fresh motor oil for $0.65 per gallon. Just need to go get some.
maddawg308
735
Front Royal, VA
Straight diesel, with a 5-gallon can of old gasoline thrown in. I also dump in oddball lots of veggie oil (unused, not WVO) and motor oil if I can get a good deal on it (better than current diesel price). I plan on doing something WVO or used motor oil related in the future, but will need to get some proper equipment together for that.
emmado22
143
Mid Hudson Valley NY
Diesel and addative, thats it. It's not worth damaging the IP and breaking down on the road away from home, or changing the filters more often that I need to with the "who knows whats in REALLY in there" used oil "fuel"
Stretch44875
Super Jr. Moderator
29
Tiro, Ohio
I'm cheap. Heating oil, old gasoline, old diesel, lots of used motor oil, hydruliac oil, veggie oil, castor oil, and about 25-50% diesel. Filter it all and run it. Have to change filters about once a year. Only thing the truck doesn't like is straight gasoline, or too much motor oil(above 70 percent). Been doing it for 3-4 years now, truck runs just the same as always. Figure I've already saved the cost of a new IP head. NO WAY am I going to pay 150.00+ to fill the tank.
Dennis
Speedy
Ontario
man this is a newbish question :oops:
you guys are using this stuff to feed your Deuces? (only deisel engines?)
are you mixing all this stuff togeather first? someone said there Deuce didnt like straight gas but likes deisel mix (you can run gas in a deisel?)
explain what you guys are doin for a newbie lol. or maybe I should read it agian :shock:
FreightTrain
Banned
2,730
13
Gadsden,Al
I have safely run 100% gasoline before in my deuce.No problems.Normal diesels won't like gas.The deuce has a specially designed engine that introduces a swirling action of the air and fuel mixture.Plus the way the injectors spray the fuel into the Cup in teh piston allows it to vaporize before it ignites.on a regular diesel the injectors fire at around 8 degrees from top dead center.A multifuel is 20-25 degrees(depending on if it is a turbo).Thta extra degrees gives the fuel time to vaporize before compressing enough to explode and start the power stroke.Most of the fuel is more or less slobbered into the cup in the piston where a normal diesel is in a super fine spray.
