quiksilver1j
- 0
- 0
- Port St. Lucie, FL
I own a m1031 with a long bed on the back. I ordered a new bed mounting bolt set from LMC but it only included 2 "long" bolts which are not quite long enough to bolt all the way through the frame. Look to be about an inch shorter then 1 long bolt that was on the truck when I got it.
I need to purchase 3 more of these bolts - 2 for the bolts nearest to the cab and the pair that are right near the mufflers ... I tried to install the short bolts near the mufflers but it is impossible to tighten those bolts unless you actually remove the muffler.. not acceptable . So I am going to install extra long bolts at all 4 locations...
Now the question is where do I buy these bolts? LMC obviously doesn't have the right size... can anyone point me in the right direction?
