Where to get the silicone hoses for coolant?
ramdough
1,729
Austin, Texas
My coolant line from the tank to engine is too short to fit my AC compressor into place. It would rub on the serpentine belt if I moved it.
The TM calls it:
Rubber silicone class Q 1” 400lb rated.
I found 50psi rated silicone hose.
Any thoughts?
Also, probably should swap the Home Depot fittings out at the elbow.
GeneralDisorder
5,187
Portland, OR
Call the manufacturer and they will help you find a distributor in your area:
If you want to have it shipped - these guys carry all the sizes:
87cr250r
1,988
Rodeo, Ca
McMaster-Carr sells it.
The top selection has a braided or spiral wire reinforced option. The braided hose cannot be bent.
The bottom selection (vacuum rated) is what you'll see at most truck shops and is very flexible.
My local Caterpillar and marine hardware stores stock quite a bit of it as well.
ramdough
1,729
Austin, Texas
Well, Private Snuffy put in some Home Depot fittings.
Any thought on where to get the proper elbow? Most I have found are not metal sweep elbows like what I have seen on other trucks.
