where to put solarizer panel ??
maddawg308
821
Appomattox, VA
All the ones I have seen were mounted exterior. Most mount it on the cowl of the vehicle just outside the windows. A few put it on top of their convoy light poles, if they have them. Mine were stupidly mounted on the side cab vent, not sure why but it never worked anyways since it had the power cord cut before it was surplussed out.
I'd say mount on the cowl, makes the most sense.
wsucougarx
65
Washington State
They must be mounted on the exterior to be more efficient (ie: not behind glass). Place them where they'll get most sun through out the day. I have had them mounted directly on the hood, cowl, and on the hardtop roof.
Darwin T
12
Port Arthur, Texas
on my M1028 it is mounted on the hood infront of the passenger.
on my M109a3 i bought some heavy duty velcro at Lowe's and stuck it to the roof of the box right behind the passenger seat almost straight over the battery box so the wire would hang straight and i used some of the little sticky zip ties to hold the wire to the front of the box. they have a little 1"x1" sticky foot that i stuck to the box and a zip tie that goes through a loop in the foot. sorry i don't have a picture of it.
Edit: here is a picture of the type of wire holder i used.
Rustygears
Ramona, CA
I put mine on top of the hardtop cab roof. It's out of the way and less likely to get smashed by something being placed on top. It's pretty invisible there and dressed the leads up the back of the cab. I put them inside mesh sleeving and tacked it the rear of the cab using RTV. I put the little controller box inside the bat compartment and attached it to the battery carrier frame with a pair of zip ties.
Jones
Sacramento, California
Here are a few pictures to give you some ideas.
Exterior, facing the most prevailing sunshine. Roof or cowl is better than tailgate or other vertical surface. A flat tab off an antenna mount or convoy light mast would be other good spots.
papakb
1,196
San Jose, Ca
Mine is mounted in the center of the hood on my M996 HMMWV about 12" in front of the windshield, like the one in the picture above. That way curious fingers don't find it.
Kurt
