guyjr
- 1
- 3
- chester md
I got a m35a1 from my uncle a couple years ago and just now getting around to really fixing things on it, needs new wheel cylinders to fix brakes and other odds and ends for safety. The real question I have is which engine do I have. He told me the original engine in it was a gasser. He had bought two deuces at the time and switched the multifuel from the donor and put it in this one. The donor has since been sold. So I don't know which type it is though. The data plate on the side of the motor doesn't seem to be there. I think I see the rivots where it was but no data plate. I also don't know which turbo it has as well. It's a pretty large turbo but on the plates it just has a bunch of numbers but no name or anything that is recognizable . Is there anything I can check to see which type I have? He said it was the continental motor but there is no proof if that's true or not. Any help would be greatly appreciated. Thanks.
I actually did a search and found out it is a 4d-454c turbo.. not sure which exactly that is but it helps.
I will post pictures tomorrow of turbo and motor as that may help more than anything.
