- 1,063
- 10
- 0
- Warsaw, Indiana
Included are photos of a White farm tractor that has the same basic engine in it as the deuce and 5 ton motors. In fact, ordnance numbers will be found on many parts in the engine when torn down. This is the kind of work these engines are doing for long hours each day at high load levels all day long with no significant problems in models of the White tractors. There is a larger model White tractor than this that uses the same engine with the power turned up more. This particular tractor has over 5,000 hours time on the same engine.
This kind of service, along with the service we get out of our turned up motors in our trucks on the farm is why I always take exception to statements that these are "come apart" motors and the flat statement "turn it up and blow it up".
I believe most failed engines are the result of poor building practice or drivers that did not care how they treated the truck before the hapless last owner bought it and had trouble with it. Failures of turned up engines can also be the fault of a driver that does not have proper gauges to monitor engine exhaust temperatures and boost levels. These engines are build a whole lot heavier inside that are Deere motors of comparable displacement. We have a lot of faith in them! In the one photo you can see the thick deck (TD) designation.
Regards Marti
Regards Marti
