- 7,564
- 10,604
- 113
- Papalote, TX
I would do a cylinder rpm drop test as suggested earlier, If you had a cylinder issue it would narrow it down.
I will give that a shot. Do I need a specific glow plug tool for these? I have done plugs and injectors in my truck 7.3 Ford with just standard tools.If the unburnt fuel is bad enough, start it when cold….turn it off within a few seconds of starting, start pulling glow plugs till you find the wet one, there is your problem cylinder….done it may times
Any chance a sticking/failed injector would cause smoke to come out the intake? I ask as the intake bolts were loose on that side and I had soot on the exterior of the intake runners and an exhaust ticking that disappeared when I tightened the intake bolts. Kinda worried I have an issue in the head.If you have a dead cylinder the idle will not change when you loosen the injector line to that cylinder, no real need for a tach.
If you have a dead cylinder it will be pretty obvious and busting the injector lines is allot easier than pulling the glow plugs.
I am not sure what you were seeing, I would bust the lines loose one at a time and see if I had a dead cylinder, then I would do as RWH said and pull the glow plug on that cylinder and do a compression test.Any chance a sticking/failed injector would cause smoke to come out the intake? I ask as the intake bolts were loose on that side and I had soot on the exterior of the intake runners and an exhaust ticking that disappeared when I tightened the intake bolts. Kinda worried I have an issue in the head.
Usually a bad injector will cause a knock, not always but most of the time.
If you do have raw fuel comming out of the exhaust it is likely a compression issue, if raw fuel is somehow being dumped into a cylinder with compression it will fire early and knock like hell.
which wire is it? Are we able to attach videos?you can also remove the run solenoid wire and if you have a cylinder that has no compression you will hear it "skip" or speed up when it comes to compress that cylinder, will not help to figure out which one though.
I post to Youtube and attach a link, others may have better ideas.disregard I found it on top of the injection pump. Other question still. Can we post videos here?
Well correction. Which wire do I pull. There are two I see on the top of the pump?disregard I found it on top of the injection pump. Other question still. Can we post videos here?
I like yours it works. I have attached the video linkI post to Youtube and attach a link, others may have better ideas.
The one towards the front of the vehicleWell correction. Which wire do I pull. There are two I see on the top of the pump?
Alright I found one cylinder that makes the idle worse when it’s tight. When I loosen that injector the cylinder idle drops slightly but the idle overalll is better. There is also a knock I am getting from it but not consistently when the injector is snugged up. The knock definitely subsided when it’s allowed to leak. Sooo sounds like I need an injector but I will verify tomorrow and do a quick start and pull the glow plug on that cylinder. Should I go ahead and do a compression check?If you have a dead cylinder the idle will not change when you loosen the injector line to that cylinder, no real need for a tach.
I would be tempted to drop an injector in, unless you just have a diesel compression gauge with the correct adapter handy.Alright I found one cylinder that makes the idle worse when it’s tight. When I loosen that injector the cylinder idle drops slightly but the idle overalll is better. There is also a knock I am getting from it but not consistently when the injector is snugged up. The knock definitely subsided when it’s allowed to leak. Sooo sounds like I need an injector but I will verify tomorrow and do a quick start and pull the glow plug on that cylinder. Should I go ahead and do a compression check?
Of course I don’t have that tool yet. Good excuse to get one.I would be tempted to drop an injector in, unless you just have a diesel compression gauge with the correct adapter handy.
Hopefully it is an easy one to get to.
