Why Doesn't My M35A2 Horn Work ?
crasheej
Hermitage,MO
I saw some from a dealer or two they just want $90. or more for the nos kit. I got mine a lot cheaper. But the flea market didn't know what it was for. My luck to be in the right place at the right time for once. Check around there out there.
runk
66
Houston, TX
If the button has been removed, good chance the wire that runs down the inside of the steering column is broken or has worn insulation that is shorted to the column (which gives you a continuous horn!). If you find that, search here, there are a bunch of threads with suggestions on how to replace the wire (it is a huge PITA).
DanDan
Cambridge, On. Canada
In my M35A2 the solenoid was removed. I have a new one but I noticed there is no air coming out of the open air line where the old solenoid used to be. I have air at the connection inside the cab. Any pointers?
Thanks,
Dan.
DanDan
OK yes thanks. Is there a certain point in the air system where a tech would block the line prior to removing the solenoid? Whoever took it off didn't just cut and bend the airline, they did it properly.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
I would trace that line all the way back to the tanks. There should be air pressure there as long as the tanks have air in them. Maybe run some bailing wire down to see if a mud-dobber closed it up or look for a kinked/crushed section. Thats about all I can suggest.
johnknp1
ky
Just to share here, I had a problem with my horn on the deuce... It started honking on its own on the way back from the sawmill one day. I was sitting in London ky at a stop light and it honked, stopped, long honked, went silent. I looked around and made eye contact the barista yuppy in the tiny little hatchback next to me. I had both hands on the wheel and he must have seen that because he looked real confused when it honked one more time. I drove another 40ish miles home with the horn going in and out of spastic honk sessions. Some people waved, some people gave me that look "yeah, you got a big truck, now stop honking at us ya bleepen jack wagon." when I got home I disconnected one of the connectors from the horn. It was honking even with everything completely off. Been running without out it for a few weeks. Figured id browse the forums on it, but my gut reaction would be to look for an exposed wire that is making contact with frame or a dirty/corroded contact just haven't had time to go fishing around for it yet.
97
39
South bend,Indiana
My deuce hasn't had an electric horn since I've bought it and I got curious one day and checked out why not. After looking at the horn button I found the wire in the column was broke so I fixed it all up and still nothing. I hooked the horn up to the batteries and it worked but nothing through the button. I found that there wasn't any power going to the horn. I checked the wire in the column and that's good I checked the connection from the wire to the harness and then from the harness to the horn and still can't find out why
97
39
South bend,Indiana
Hi so my electric horn is throwing my head in a circle. I've taken the button apart found the main wire was broke, fixed it still nothing. Checked the connection at the base of the column nothing wrong there, checked at horn nothing wrong there. Found I'm not getting any power. Any reasons why? Am I missing something ?
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
You should have power at the horn at all times with the switch on. The horn is ground side switched. So when you push the horn it sends a ground signal to activate the horn.
Sent from my SM-G965U using Tapatalk
my blood flows OD
strafford new hampshire
That is the same issue I’m having in my m-813.
horn wiring appears to be the same as my wife’s deuce.
97
39
South bend,Indiana
My switch do you mean service drive? I know online they said if you turn your service drive on and your lights come on you should have power to your horn. After checking I still don't. I don't know where I'm losing power from if that's true because my headlights come on and I tested them and they come up with 24v
pjwest03
37
Vestal/NY
The horn power is fed from a circuit breaker on the firewall, upper driver's side. There will be one or two breakers if you have a heater installed or not. Those connections tend to be fried from age. Also, the breaker could be bad. On my deuce, I had to replace the breaker and run a new 24V line to the horn.
97
39
South bend,Indiana
My truck had a heater at one point but I think it got taken off. I see there used to be something on firewall. I have 2 female connectors just hanging there now. But I dont see any circuit breakers. I dont even know what it would look like
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
Moderators note: the thread "Deuce horn not working" has been merged with this one, so we don't have two threads about the same topic, running parallel.
pjwest03
37
Vestal/NY
Could a new feed just bypass the circuit breaker? From the battery up the column and soldered in with original horn wire?
It would be a fire hazard to not have circuit protection. You don't have to use a breaker but an in-line fuse would be really good idea. Fuse should be as close to the source as possible. The fuse's purpose is to protect the wire in case of a short.
