winch problems
Green Dog
Niceville, Fla
As I engage the winch to just pull the vehicle along all is good-vehicle slowly being pulled. Get inside and apply a little brake pressure and the clutch lever on the winch jumps out of gear. Have lubed the shaft area where the clutch lever is connected to said shaft. Am puzzled?
1,169
2 man operation. You should not engage the outside lever with the pto engaged.
and be warned, you can NOT disengage the outside lever under a load.
You are supposed to engage and disengage the winch from the operator seat with the clutch and pto only.
1,169
Damit man, the disengagement mechanism is square face cut(like a love joy coupling). You cannot reliably get full engagement if the PTO is driving the winch input shaft.
If you engage it before running the PTO, do you have the problem?(pull out on the cable while pulling the lever to engage it)
If you continue to use it wrong, it will only mess up the coupling more.
colelkhunter
OK........let me say. First off, your not gonna get very far with a post like that. Second you had a legitimate question asked " was the winch fully engaged". Third...Doghead explained to YOU the proper way of using a PTO military winch. If the winch was engaged with the pto already engaged then your first answer is NO it was not fully engaged. Engage winch first. Then get in the truck and engage the PTO, then let off the clutch. THEN apply the brakes a little if you want to feel resistance. Ask a proper question and you get a proper answer. Don't act like a spoiled child who can't get him way from mommy.:deadhorse:
Heavysteven
10
Hickory Flat Ga
Greendog your response to Doghead was rude and negative. I would like to remind you to treat others with respect.2cents
After reading your posts it is my conclusion you do not understand or know how to properly operate the winch. You need to engage the lever on the winch first, then go into the cab. Holding the clutch down select a drive (high low or Reverse). Let out on the clutch and the winch should operate with out slipping.:deadhorse:
1,169
Merry Christmas ...
FMJ
37
Las Cruces, NM
DH you should have just told him his winch was f-ed, rebuild it. . .
also sensing a SS membership total decreasing by one :shock:
