window crank handle
WillWagner
2,418
Monrovia, Ca.
No. They are standard GM crank handles. You can get them at Kragan, PepBoys, etc
Barrman
1,602
Giddings, Texas
The M35 has a square post for the window crank handle. The CUCV has a round splined post for the handle.
The M35 handle is held on with a screw in the middle. The Chevy handle has a spring clip on the shaft behind the splines.
I suppose you could make a round peg fit a square hole, but it probably won't be worth the time and effort.
