mdemars03
- 0
- 16
- El Paso, Texas
I have read the posts and looked at the TM's so I do see what it would take to replace the window regulator. My question at this point is before I go replacing parts is there anything that can be tightened on the regulator or anything that can be fixed for the window to keep my passenger side window from going down on its own. It seems like if you just look at it wrong or a slight breeze blows it will roll down by itself. I know I can replace parts and most likely fix the issue but I would like to try and fix the problem before I order anything.
