Winter shift boot option
Dieselfitter
236
33
Cody, WY
Winter shift boot for transmission is easy. Arctic military canvas or a speed shop high rubber tower type.
the transfer case hi low lever adds some issues in that the shifter lays on the floor when in low. And i use low alot when logging ,
a door sweep broom type at any lumber outlet is cheap and effective way to seal up cold air. 5868856C-9B41-4152-A4E6-B04FE77BBB0A.jpeg
Iron Maiden
100
Oregon
I made my transfer case shifter boot in a similar way. Posted Here . I originally used rubber, but the rubber I chose probably wasn't the best for this application and a few pieces of the rubber ended up coming apart after several months. I then decided to use a brush also and it's been much better.
Dieselfitter
236
33
Cody, WY
Nice touch wih the L N H trim plate. Your truck is much more refined than mine. Lol My truck is and will stay a lil “dirty”
i have plugged all the holes i can find in the cab and installing a fiberglass top on it this week . Hoping that will quiet the cab more and keep the heat that it makes . So far in 30* weather the heater keeps up on these back roads , 25-35 mph. i have a 5 mile stretch down a paved road at 50 mph to the mill, the cab is cooled off by the time i get there.
