winterization kit instructions?
jwaller
19
Columbia, SC
I just received a artic winterization kit and I did not get the directions. does anybody have them?
it's the multifuel heater part and all the brackets that I cant figure out.
also it came with some strangely bent sheet metal that I've not seem before.
jwaller
19
Columbia, SC
that does help but I already have the coolant heater and I need the diagrams for hooking up the multifuel in its entirety along with the routing of it's fuel lines and exhaust pipe.
papercu
33
Baxley, Ga.
TB
I have the TB 9-2855-42 Personel Heater kit for the 5t M39 Series but dated 1956 is it for the gas engines? Will it work or be usefull for the deuce mulifuel?
I've sent it to be added to TM section. Wayne
jwaller
19
Columbia, SC
RE: TB
thats so much. any info will help. The problem I have now is how to mount the plate that holds the fuel pump and the sheetmetal piece that goes under it. it looks like it extends under the batteries but I'm not sure.
miltruckman
Lebanon, Indiana
Here are some photos of the arctic kit installed in my M342A2 dump truck,
Bill
Michigan
BKubu
1,237
Gaithersburg, MD
Is the front of the heater that is on MILTRUCKMAN's dump made for ducting that would go to an air scoop like those used with the hot water heaters? Also, I've seen two types of fuel burning heaters. The one that is on MILTRUCKMAN's truck and the one in the attached picture. Is one better than the other? Is one newer than the other? Is the one on MILTRUCKMAN's truck really intended for the rear compartment of a deuce cargo or shop van? I wanted to mount a similar heater on the hood of one of my trucks. Thanks in advance for any replies.
