Wiper Extension
ewylam
Salem
Can anyone confirm if this is the correct wiper arm attachment or if there is some extension installed. If it is an extension, any idea how to remove it to install the correct wipers?
DREDnot
643
Avondale , AZ
My guess is a wiper extension for the thicker armored windshield glass?
I haven't seen one with my own eyes yet.
Does it have a set screw on it somewhere?
Hit it with some PB Blaster just for good luck.
Coug
4,842
Olympia/WA
it's just pressed on. I used a couple of claw hammers to pry it off. Just be careful not to slip and hurt your windshield glass.
I ran mine for a half year with the extension in place, it didn't seem to affect wiper performance.
TOBASH
3,989
Brooklyn, NY
I own a set... It is not just pressed on Coug. After pressing in place it is retained with a very small screw requiring removal with an allen type screwdriver.
EDIT - Sorry if the tone of my post is terse Coug. I'm tired and cranky... My son is choosing colleges. I'm choosing ways to go into debt.
Coug
4,842
Olympia/WA
Doh.
Well, I didn't see it. I'd imagine if installed properly it faces down so you can't really see it when working from above. I do know mine came off without too much difficulty though. Didn't cause any damage that I could tell, or that affects putting the wiper arms back on.
Retiredwarhorses
4,643
Brentwood, Calif
The wiper pivot extensions on the m1123 don’t have the Allen set screw, they are pushed on and blue locktite was applied. Problem now is, 11yrs later, the 2 pieces are fused together attempted to remove no less than 40 pairs of these, I’ve been successful on maybe 5. So if they don’t come off, I just replace the pivot.
the set screw extensions are a different version, they are longer, there are various lengths based on what windshield setup you have.
ewylam
Salem
Good to know the wipers will work with them on. I'll see if they come off easy and if not probably just leave them on. I'll update how my attempt to remove them goes.
Squirel
12
Fairhope, Alabama
I was able to easily remove the extensions on my 1123 with a slide hammer. I tried to pry them off with hammers and wonderbars but was worried about the frame and the glass. The slide hammer took the first one off with two hits and the other one came off with one hit. I may have bee more timid on the first one and a bit more confident on the second one.
TOBASH
3,989
Brooklyn, NY
Those things sell for a few bucks on eBay. I seem to recall around 40 or $50 for the pair. You guys might all want to consider selling those pieces. It’s a tight economy and every little dollar helps.
Stay healthy guys.
T
Coug
4,842
Olympia/WA
Stay healthy guys.
T
Nah, I'll keep them so I can put armored windshields in later after the apocralypse happens.
But that's only if I can figure out where I put them. Amazing how many things I can misplace in a week.
ewylam
Salem
Well, I removed the paint on the extension and verified it does not have the allen screw. They also don't appear to be pressed on because there is about 1-2mm of play on it. It's very hard to see but there may be a retaining ring holding it on. Ring any bells?
Squirel - was that how yours were? How did you attach the slide hammer to them?
Retiredwarhorses
4,643
Brentwood, Calif
they are held on with locktite, they need a torch to heat them up, I remove a couple sets a week, they are really on there.
there is no Allen screw like the new style, there are several styles.
the slop you speak of is the pivot shaft, if you pull on them enoug, it will separate and render the pivot useless.
TOBASH
3,989
Brooklyn, NY
My set definitely has an Allen key cause I used one.
Guess there are a few types
Sorry if I created confusion.
