Wipers not working
rookie
portcharlotte fl
Hey guys i had the wipers working and then yesterday i went to try them out and they werent working weird huh. Well it gets a liitle weirder i turn on wipers and i pull back on the windshield while im sitting down in the drivers seat. And i have wipers turn on working great then i realease some pressure from the windshield and wipers turn of . Anybody has experienced with this im thinking it might be a grouinding issue..
DatGuyC
22
Essex, Maryland
There is a contact connector between the windshield and the body that powers the wiper motor, sounds like it doesn't have a solid connection. Part number 12339327
KansasBobcat
San Antonio, TX
The contacts are spring loaded and mounted in a rubber base so they can get compressed over time and not be making good contact. Also, there is probably some corrosion on them.
MarkM
CODE BROWN...It's all going to sh~t !
1,969
WOBURN. MA.
Just where is this switch as I now have this problem..
Mark
BLK HMMWV
497
Pasadena California
the switch is on the wiper motor. that is the only switch. If you have a soft top HMMWV you have 3 contacts on the body under the windshield frame and on the bottom of the windshield frame.
MarkM
1,969
WOBURN. MA.
Ok but where are these contacts? Middle left right? Thanks again.
Mark
