USAMilRet
- 15
- 18
- Tampa, Florida
Duplicate
Voltage drop is proportional to current (load). No load means no voltage drop. At these values I'm not really worried about it. 7V @ 56A isn't a big deal. 4.4V is certainly better.
Where it comes into play most is with motor starting. You need a good voltage and amperage kick to get a motor turning. If it were me and the cost wasn't too great I would go with #6.
Great suggestion.
What is an 480/3 phase instigator at 100hp?Here are a couple sources of 2-2-2-4 al.
https://www.wireandcableyourway.com...MInai5lsD02wIVgh9pCh3glg-IEAAYASAAEgK7fPD_BwE
https://www.homedepot.com/b/Electrical-Wire-Service-Entrance-Wire/N-5yc1vZc578
Buy a bit extra....don't run yourself short.
We use this type wire for 480/3 phase instigators at 100 hp a couple thousand feet out.
Sorry, that was "irrigator". Pumping an 8" well. It would not be a #2 for that HP...probably 2/0-4/0.What is an 480/3 phase instigator at 100hp?
Are you load banking your set with the wire coiled on the spool? I remember reading somewhere about heat being an issue when you run power through a coil of wire. Might be worth looking into...Got my wire. Type W 100ft and it weighs 100lbs. Had to unroll the spool to get to the other end, leave 10ft out and respool.
