Did a little bit of work on the M1078 today as I'm getting ready for a parade in La Grange (yes the one ZZ Top sings about) next Saturday. I'm going to be hauling the Board of Directors for a new museum that's opening so I need to have the sides up so they can be seen during the parade.
First order of business was working on the front of the cargo cover. I've had problems with it riding up since it was first installed, then the AC shop broke one of the super ropes so I had the driver's side secured with a bungee strap. Unfortunately, according to the TM, I'm missing a couple of straps with metal hooks that tighten the front of the cover down to the bed (Item 30 in the TM drawing). I may be able to fab something that will work but in the meantime it'll just have to survive the way it is. To get access to the j-hooks on the bed on the passenger side you have to lower the spare (makes no sense but it is what it is). After doing that I unhooked the passenger side super rope. The way the top came new was 2 super ropes on the front - one for each side but not connected. I like the idea of having 1 continuous piece all the way across the front to keep it snug so removed the old right side (left was already off since broken) and took a spare longer piece I had to make a new rope.
If you haven't worked with the LMTV style rope and connectors it's a lot different than the old M35 style cover rope. In order to take it apart you 1) pull the collar from the hook down 2) pinch the hook base opposite of where the barbs are 3) pull the hook off the rope. Once you have your length where you want you 1) make sure to put the collar on 1st oriented in the correct direction 2) push the rope into the hook until it bottoms out 3) pinch the barbs into the rope 4) slide the collar back in place.
Also if you haven't worked with these before your first instinct might be just to snap the plastic hook over the j-hook of the bed. That would be incorrect (according to the TM). What you do is make a loop by connecting the hook to the 1st D-ring on the cover and pulling that loop over the j-hook.
Now that the front was secured better than before I decided to roll up one of the sides to see what type of clearance I'd have for the passengers. I think the troop seat bar may be in the way for any short people. I'll need a Soldier B to model before I make any further decisions there.
I also wanted to try the Driver Warning Alarm out as I haven't done so yet. Again, no Soldier B so I had to improvise with a zip tie as the switch is spring loaded. For those who haven't tried this on your truck it basically uses the low air buzzer but rather than continuous it cycles through kind of like a British Bobby Siren. Quite load and mine works fine.
Tomorrow I'm going to add some inside the bed storage boxes for my tire changing equipment and regular tools since the truck tool box is woefully undersized and leaks like a sieve.
