WOW, Just wow. Nasty !
frodobaggins
Ruston, La
Did you change the oil in the diff? How does that much crap actually squeeze itself in there. It is like the drum wasn't even there.
Had several failed attempts to get it out, as well as it raining several times. As stated before, the wheels were almost completely below grade, so the silt/mud filled in all open spaces as it filled in the hole.
Heavysteven
10
Hickory Flat Ga
I would buy ten cans of break cleaner, replace the seals, boots, repack the bearings, and change the gear oil call it a day.
Good photo's thanks for sharing:beer:
rat4spd
10
Evansdale, Iowa
So the frunnel is now closed for business? I'm betting that th eprice of Chinese goods will now go up as shipping costs went through the roof now that your access is closed.
jimm1009
68
Louisville, KY
I don't mean to sound pesitmistic but I would plan on bearings & outer races too if you moved it very far with that "stuff" in there.
If the bearing rollers have any rust they will fail on the road or worse, down the road.
Jimm1009
:deadhorse:
