MADSAM - That rust inside the leg tubes is going to be a PITA for the rest of the time you have the truck unless you get it out of there. The rust is thicker than the steel which rusted, so it will always bind unless you get most of the rust out. You need to get something to dissolve the rust like Naval Jelly. Try a hardware store and see what they recommend. Also try an auto parts store for a product called Metal Prep or something like that which is used to clean body metal before painting.
Maybe you can build up a custom sand blast nozzle to get inside there and blast the rust out. Or put some emery cloth on a stick and sand it out.
The best thing for removing rust is Muriatic acid, but unless you KNOW what you are doing I wouldn't recommend it. I have used in the past and it does work very well.
