Wrecker Owners, Stand up and be Recognized!
sandcobra164
323
Leesburg, GA
I figured out my pulling power problem on 16's. Factory tune is only 515 hp but it's now bumped to a CAT tune on the C15 at 625 hp and 2,050 ft. lbs. of torque which is about as much as a stock C15 on sequential turbos will put out with only a plug and play tune. Brakes are fine as they are full air brakes on this rig. The tune up helps when hooking to other similar sized trucks and grossing over 100K on big tires.
73m819
329
gainesville, ga.
There is a BIG difference in stopping a 543 compared to a air brake truck on 16.00s, even 16.00s on a air brake truck that did uses them as stock will cause longer stopping distance.
houdel
11
Chase, MI
Google is your friend. How much do you want to pay?
There is a M816 on Ebay at $5001, reserve not met:
https://www.ebay.com/itm/5-Ton-Cran...124981?hash=item4d97e93575:g:8rAAAOSwwR5dFTEI
Eastern Surplus has M809 series in the $11.000-$15,000 price range.
https://www.easternsurplus.net/VehiclesList/24/M809-Series-5-Ton-Trucks/1
Midwest Military Equipment has several M936 wreckers in the $28,000-$30,000 price range:
https://midwestmilitaryequipment.co...tary-6x6-wrecker-crane-truck-45-000lbs-winch/
Floridianson
2,531
Interlachen Fl.
That's some solid ground the rigs are rolling on, guessing it was a dry season.
What's the new home where your "children" are headed?
Became a grandfather Dec. 11 with a baby girl on my sons part in the mix. Still trying to clean off the 5 acres of all OD stuff collected so I can sell the property as I do not need two homes at my age. Yea my field is always solid even in the rain. Thanks for asking.
Ajax MD
1,435
Mayo, MD
I'm glad this thread was started.
Yes! Wrecker owners, please stand up and be counted so that when I break down in my M813, I may call upon you for mercy and a tow home! 😟
