WTEC III Fault Code D1-6600
jtcawrse
Mexico
Here is the latest.
There is continuity there between pins 5 and 45.
Battery are all independently 12.55-12.65.
Still no shifty.
The transmission is protecting itself. We just don’t know what from.
Rear glad hands were capped when the rear storage box was installed.
Any other ideas and suggestions welcome.
Skyhawk13205
310
Alaska
Here is the latest.
Still no shifty.
it seems like to me you need to find out where the comms are being lost. Allison ecu to key pad or CAT ecu to Allison ecu
You can check the serial connection from the keypad to the Allison ECU. Disconnect keypad and Allison ecu ohm out the wires from A to black S1, and B to black s17.
good luck
Skyhawk13205
310
Alaska
good luck
i need to correct myself the serial comm is not from the keypad but to the diagnostic connector. You might have to check your termination resistors for your 1587 and your 1939 data bus
Suprman
706
Stratford/Connecticut
I can connect to the wtec3 round diag plug on first gen trucks. Its a slower setting and you dont get much more info than the keypad errors. Its more than likely a wiring issue or bad tcm. I have a good tcm on hand. If you take the grill off on the drivers side of the hump the cab to trans harness comes out its a twist lock sometimes hard to get off. The bundle comes down and turns back towards the engine. Inspect the wires there. Sometimes you have to peel back the wire loom cover.
jtcawrse
Mexico
From Quade this morning:
Just spent the last hour doing continuity tests on the harness. All checks out.
Sent from my iPad using Tapatalk
