tm america
- 23
- 38
- merrillville in
I was driving home from work today and going up a little hill so i pushed the go pedal....And something changed... I'm guessing something with the injection pump...The truck took off like crazy pulling hard to 70mph up hill? The boost gage spun around past 40psi and actually broke the needle when it went all the way around.. scary...
Now it feels normal unless i get into it above 2000rpm.. then it shoots the boost up like crazy.....
I just put this motor in a few months ago .I did the head gaskets and filters when i put it in ..It was down on power So i turned the fuel up .. It has been running great since then till now.. I wonder if i had a plugged injector or something that finally freed itself up..
. Any ideas on what could have happened to make it go from 20 psi boost to 40 psi plus .. instantly?
![Driver :driver: :driver:](https://www.steelsoldiers.com/images/smilies/driver.gif)
