- 410
- 35
- 28
- Atlanta, Ga
The original liner in the passenger side fuel tank is very badly deteriorated and starting to clog the fuel pick up from time to time. I've removed the filler neck assembly and have fairly good luck pressure washing out all the old led, scum and most the original liner down to bare metal. It flash rusts fairly quickly, but I'm not worried about that. what I am concerned about is the liner on the top of the tank and in the hard to get spots around the fueling point. i have a pressure washer whose nozzle can swivel up to 90 degrees, but there are some areas I still can not reach. I removed the fuel pick up line as well as it's rough and was curious about the screen filter that goes on the bottom of it. I think i have a solution for it, more than likely will just make another pick up line from the CU-NI easy flex line in the same size and then braze one of the aftermarket fuel strainers for an M38(A1) on the bottom with hte pick up almost at the bottom of it.
before I can do that, do i need to reline the tank (as I would like to do) or can I leave it metal like most gas tanks. I'd like to get everyone's opinion on what to do with this tank and what to use to liner it, as I will either have to use a small sprayer to get to some parts or a brush attached to a stick to get the far end. I was thinking of using Red Coat and a brush and just paint the inside of the tank with it, since turning the tank over and around to coat the inside would be a little difficult, at a minimum.
Let me know what you think and looking forward to everyone's thoughts or experiences in dealing with this. Again, I'm not worried about the flash rust as should not affect the ability of the Red-Coat to stick.
Last thing, should I just take the vehicle to a place that relines equipment intergral fuel tanks?
Thanks
Jason
Thanks
Jason
