WTK: LMTV Shock absorber options
coachgeo
3,551
North of Cincy OH
So I ordered some Monroe Magnum 65456 but they are way to short , are there two versions of these shocks? I measured the 65456 and extended its 26" but the Monroe chart is stating EXT is 32.88.
Edit - Never mind seems the one I opened was different then the other three / others fit perfectly / I will need to go to tractor store to get an insert for the shock eyelet bushing the are pretty big and even the lower bolt which is pretty big has slop in it . Looks like the first shock has been miss labeled
keep in mind..... bolts I think are different sizes. iffff I recall right it was like top and bottom are different..... or it was rear axle vs front axle.... maybe both..
j_boucher
110
Virginia
Yes there is a different in size the top for all 4 are the same ( a smaller Bolt ) and bottoms are all the same , with that I went to a farm store and got some 8 lift arm bushings 1/1/8 to 7/8 reduction part number 228CO006TSC for the shock eyelets and these are fine for the lower bolt size , for the upper bolt I picked up 4 Lift arm bushings 7/8 to 5/8 reduction part number 228C002TSC these fit perfectly inside the other bushing and reduce it perfectly for the upper smaller bolt .
So I don't have a press so what I did was throw the larger bushings in the freezer over night then pressed them in with my vise I did notice they may need a trim as they are barley to large and caused one side of the shock rubber to bulged a little , however when I tightened it down it evened out " I know this because I took a shock apart and noticed the rubber evened out" The smaller bushings for the top bolts slide perfectly into the larger .
Shocks are in but haven't taken it out for a drive yet I will be doing it later today
So here is what ordered in total
4 Monroe Magnum 65456
8 Lift Arm bushings - 228CO006TSC, fitted into the 65456 eyelets
4 Lift Arm bushings - 228C002TSC inserted into the upper eyelets "inside the 228CO006TSC" for the 4 upper bolts
MatthewWBailey
1,905
Colorado
Did you ever install the 65456 ?
I just did
Ronmar
8,392
Port angeles wa
Found my notes from an off-line conversation I had on this subject. the person I had the discussion with pointed out some other possible options from Bulldog, Gabriel and Ford.
from my looking the Monroe, Gabriel and Ford all had the same specifications. The Bulldog was the same overall/extended length as the
LMTV originals, but had 1” more travel, so ~ 1” shorter compressed length… He was going to try the Bulldogs, but I never heard back how or even if that went…
65456Monroe Shocks & Struts
85376Gabriel
F6HT18045LAOEM(think this is a ford P/N)
HD1215-0126Bulldog HD
