X-door refinishing
kcobean
Sterling, VA
Ok, so I'm the proud owner of a beat-to-**** set of X doors. They need to be be refinished, bondo'd and and painted to match my truck. I'm trying to gather information about the refinishing process. Some areas are down to the gel-coat, but most surfaces are tan carc over green. Can anyone recommend what product to use to fill the divots where it's down to the Gel coat? I've heard that you shouldn't use bondo because of how it cures and adheres to FG vs. metal. Also, what material is recommended to paint with that will adhere to the carc for longevity?
medic2410p
Brandenburg, KY
I took mine to a friend that does body work to fill a hole and patch up a crack in mine. He used a fiberglass gel like material. Not the mat. I cannot tell where the repair was after.
No if`s or but`s ....do not use bondo anywhere. Only thing to use is 2 pack epoxy ( like Westsystems ) and depending on the repair with or without the micro fillers. If you can`t get the correct primer for X doors then use a 2 pack primer system that is used in the boating industry.
911joeblow
72
Utah
Basically you are doing fibreglass repair and as such are using resin and depending on the level of damage matting might be needed too. Bondo is for metal repair on the cheap.
