XM-778 2 1/2 ton Cargo Truck, W/W
citizensoldier
19
Northern Michigan. Smelt City
More images of the xm757 axles.
View attachment 588250View attachment 588251View attachment 588252
The front axle is FM210 RDAX5
Rear axle; M210 RDAX2
Axle ratio: 6.40, no lockers
The xm778: FC240 RDAX1, ratio 6.72, lockers (according to dash controls)
The two air lines on the hub of the xm757: service brakes and pressurization
Do you have any close up pictures of the rims/wheels for your truck Bjorn? What's the availability of them? Hens teeth? I am wondering if they could be modified to work on Andrews truck. A few of his are in real bad shape.
cranetruck
94
Meadows of Dan, Virginia
Very difficult to find...here are a couple of images.
2009 0531 Sunday, wheel and lock ring, 1r tire, P5310024.jpg2009 0601 firestone wheel, 50lb (3).jpg
59apache
Chipmaker
1,299
30
Bavaria / Germany
Doesn't belong here....i've heard about prototypes with a Cummins 6BT..does anybody have infos about?
BTT:
Very nice truck! Congrats!
citizensoldier
19
BTT:
There used to a be a person on here that owned one of them but that has been a few years ago. There has been two that I have seen auctioned off on GL.. Very unique truck has a different transmission also if I recall correct.
Jeepsinker
470
Dry Creek, Louisiana
I don't think any custom wheel makers would take on the liability of manufacturing any kind of split ring rim these days. All it would take is for one person to get maimed or killed and they would sure enough be out of business.
If anyone would have some originals, it would be Jack down in Tucson. However, these rims are ten lug, and the ones for this deuce are six lug right? So it won't be a bolt on anyway. You could probably make adapters, but I'm sure you'd have to modify the rims. It might be worth checking to see if you could make some Goat rims fit, even though they are smaller and you'd have to figure out tires all over again. Nevermind, just forget that last part. It was dumb.
